MikeyRS Posted May 8, 2008 Share Posted May 8, 2008 did the thermostat open when in boiling water?? and then close when taken out?? Link to comment Share on other sites More sharing options...
onehotminute_191 Posted May 8, 2008 Author Share Posted May 8, 2008 did the thermostat open when in boiling water?? and then close when taken out?? well how do you mean open? i didnt look like it moved much to be honest lol. what part has to move in what direction? theres 2 springs holding the internal shaft part and the small plate at the back. Link to comment Share on other sites More sharing options...
MikeyRS Posted May 8, 2008 Share Posted May 8, 2008 did the thermostat open when in boiling water?? and then close when taken out?? well how do you mean open? i didnt look like it moved much to be honest lol. what part has to move in what direction? theres 2 springs holding the internal shaft part and the small plate at the back. it should open out when in boiling water, the whole point of the test -> http://static.howstuffworks.com/gif/cooling-system-thermostat.gif if it doesnt open (and then close when taken out) then its fooked Link to comment Share on other sites More sharing options...
onehotminute_191 Posted May 8, 2008 Author Share Posted May 8, 2008 ok ill test the old one just out of interest. but it seems like its opening because the pipe that runs away from the stat once its open get really hot. only after a while though, the pipe on the other side that circulate inside the engine are hot pretty quickly then after 5 minutes or so the big pipe going to the top of the rad get red hot. well not red, but you know what i mean Link to comment Share on other sites More sharing options...
MikeyRS Posted May 8, 2008 Share Posted May 8, 2008 Ahh youve already replaced the thermostat with a new 1?? Link to comment Share on other sites More sharing options...
onehotminute_191 Posted May 8, 2008 Author Share Posted May 8, 2008 Ahh youve already replaced the thermostat with a new 1?? yeah. replaced that and also the fan temperature switch. if i short out across the fan temp switch and bypass it the fan comes on. well it latches the relay behind the battery that switches the fan on. i havent let the engine run too hot. ive let the needle go up to 'm' on the guage where it says normal. Link to comment Share on other sites More sharing options...
MikeyRS Posted May 8, 2008 Share Posted May 8, 2008 just read the thread prop now and i would prob have gone for the relay not many other things left to try now Link to comment Share on other sites More sharing options...
rogerthecabbyboy Posted May 8, 2008 Share Posted May 8, 2008 is it a ford fan switch? i used a 'quality' part from qh and it didn't work, used a new ford one and bingo working fan Link to comment Share on other sites More sharing options...
onehotminute_191 Posted May 8, 2008 Author Share Posted May 8, 2008 no it wasnt i thought about that lol. wonder how much they are from fords. i just picked it up from the place i normal get odd bits from. ill try a relay and if not might have to get all genuine parts and try again Link to comment Share on other sites More sharing options...
rogerthecabbyboy Posted May 8, 2008 Share Posted May 8, 2008 £11.55 in vat when i got mine july last year, just checked my car file lol Link to comment Share on other sites More sharing options...
onehotminute_191 Posted May 8, 2008 Author Share Posted May 8, 2008 £11.55 in vat when i got mine july last year, just checked my car file lol hmm might go there tomorrow then. Link to comment Share on other sites More sharing options...
Stu Posted May 8, 2008 Share Posted May 8, 2008 You say the relay switches when you manually bridge the fan switch plug, but does the fan actually spin up? Link to comment Share on other sites More sharing options...
Craig855S Posted May 8, 2008 Share Posted May 8, 2008 You say the relay switches when you manually bridge the fan switch plug, but does the fan actually spin up? if it doesnt then its the fan motor,so new fan time..scrapyard cheapyness..in fact,i have one u can buy Link to comment Share on other sites More sharing options...
Stu Posted May 8, 2008 Share Posted May 8, 2008 Not necessarily scoop. He said the fan works with the AC. Link to comment Share on other sites More sharing options...
Craig855S Posted May 8, 2008 Share Posted May 8, 2008 if i short out across the fan temp switch and bypass it the fan comes on. well it latches the relay behind the battery that switches the fan on. Yes it's all from the fan switch... if you have a/c then there is an additional circuit to switch the fan on half speed..yeah thats working. it must latch the relay on and the fan switch circuit must also latch the relay. seems strange but ill try the stat and post again soon.cheers got confused stu..altho maybe 1hotminute could clarify. does the fan come on when AC is on? or just the clicking relay?Cos when he bridges the thing he says it clicks....but doesnt clarify weather the fan spins or not with the clicking Link to comment Share on other sites More sharing options...
