sub problems
splinta
  • Replies 39
like said, check your earth cable, i put mine on me suspension top mount bolt, to determine whether remote is dodgy, remove them remote cable from the amp, get a small piece of wire and bridge the live and remote, light should stay on, as it would of done before, check fuses, replace if ya want to, make sure your using oxygen free RCA leads, better sound quality, make sure live and earth cables are at least the thickness of your thumb, thin cables can over heat and burn out, causing a fire.
also how many channels does your amp have, wiring them to the wrong channels can be the problem, if all set up correctly then id say amp is blown, may light up but nothin happens which points to the channels
