sidrick Posted June 3, 2014 Share Posted June 3, 2014 What exactly is your ECU problem? Do you just need the pin outs of the two ECUs to compare? Do you know if your replacement ECU is working both before and after you plugged it in and hoped for the best? Link to comment Share on other sites More sharing options...
scottybo Posted June 3, 2014 Author Share Posted June 3, 2014 i want any information on an aqua ecu. do i need an edis loom would be a good start? Link to comment Share on other sites More sharing options...
sidrick Posted June 3, 2014 Share Posted June 3, 2014 I think a good start would be to identify what you have, and what you're trying to fit it to. It'd also make it easier for folk to help. Does the original car/ECU have PATS and does it have internal or external EDIS? Does the replacement ECU have PATS and does it have internal EDIS? Link to comment Share on other sites More sharing options...
scottybo Posted June 4, 2014 Author Share Posted June 4, 2014 the original is fitted with pats, i am unsure on edis, where would i find the loom for that? the replacement ecu is also pats, i have the ecu itself, the ignition ring, the key, a pats box and external edis loom Link to comment Share on other sites More sharing options...
sidrick Posted June 4, 2014 Share Posted June 4, 2014 It's odd that you have an external EDIS loom with the AQUA ECU as in this thread you're advised that that ECU should be internal EDIS - http://www.escortevolution.co.uk/forums/topic/151123-ecu-question/?hl=edis&do=findComment&comment=1528166 In fact I'm sure, as that guy advised, that with the info he posted and a multimeter then you can work it out without too much problem. Link to comment Share on other sites More sharing options...
scottybo Posted June 4, 2014 Author Share Posted June 4, 2014 his thread says aqua is internal edis, so i should be able to just plug it in and away i go, but thats not the case, iv plugged it in, plugged in the ignition ring, held the matching key inside the ring and tried to start it and i get nothing no fuel pump, no starter motor, nothing Link to comment Share on other sites More sharing options...
sidrick Posted June 4, 2014 Share Posted June 4, 2014 What's the red light below the clock doing? Link to comment Share on other sites More sharing options...
scottybo Posted June 4, 2014 Author Share Posted June 4, 2014 im at work atm, ill check back when i get in and let you know Link to comment Share on other sites More sharing options...
scottybo Posted June 26, 2014 Author Share Posted June 26, 2014 ok so ive made some progress, i now know my aqua ecu is external pats, and by onis ecu is internal, so i need to wire in the pats loom. or find an internal pats 1.8 ecu, issue with that is that they would all be 115 ecu's Link to comment Share on other sites More sharing options...
bongo Posted June 26, 2014 Share Posted June 26, 2014 Try a 2.0 pre pats ecu,deep,Dale,desk,dewy.....can't be that far out. Link to comment Share on other sites More sharing options...
scottybo Posted June 26, 2014 Author Share Posted June 26, 2014 worried about it overfuelling and killing it. im currently not using it because i know its underfuelling Link to comment Share on other sites More sharing options...
lee grout Posted June 26, 2014 Share Posted June 26, 2014 Its this type of thing that puts me off the idea of a different engine! I hope it gets sorted soon. Link to comment Share on other sites More sharing options...
scottybo Posted June 26, 2014 Author Share Posted June 26, 2014 I expected this 100% as its the first time i ever changed one Link to comment Share on other sites More sharing options...
bongo Posted June 27, 2014 Share Posted June 27, 2014 dont worry about overfuelling too much, it wont do no harm,and will only be slightly. Link to comment Share on other sites More sharing options...
bronze4door Posted June 29, 2014 Share Posted June 29, 2014 i have a cast ecu out of a 130 spec mk5b but i do not have key for it with the right chip but i have been told you can get the standard key re programmed to match Link to comment Share on other sites More sharing options...
