Damp patch :vangry: HELP!
13 replies to this topic
#1 JC
Posted 24 May 2014 - 01:00 PM
My Escort MK6 has developed a damp drivers side front foot well, can't see anything obvious, anyone got any sensible suggests as what it is causing it and how I can resolve? thanks
#2 demented
demented
Posted 24 May 2014 - 01:27 PM
Sunroof drainage pipe been disturbed and not allowing water to escape from vehicle, however, I can't remember the correct route of drainage pipe.
Maybe water entering through speedo cable grommet, behind wiper motor.
Water entering via window seal, running down inside of door and through door drainage holes into foot well when door closed
Worse case; corrosion under the wiper motor area and hole created.
Corrossion under carpet, either the floor pan front seam adjacent to base of foot pedels or where floor meets rear of sill under the car.
#3 shawdreamer
shawdreamer
  • Drives: 3Dr Mk5b, and the missus's head into the headboard while gaping her rear
Posted 24 May 2014 - 04:16 PM
you forgot one of the most common culprits?
heater matrix/pipe failure
any monkey can buy and bolt on.... an individual creates
you have to really ask yourself something when you consider trying to insult me.. do I really seem like the type of person who gives a flying shite covered monkey F*ck about your pointless comment?.. I'll save your deminished intellect the struggle..that'd be a "No"
Anything can be made to fit.... thats what hammers are for silly!
All posts are the view of the writer and not necessarily that of..... actually no, I dont really give a flying flame toasted turd, dont read my posts if you dont like em R-tard.
no one can accuse me of being "two-faced", Ill call you a nob behind your back and to your face... the latter preferably so I can watch you uselessly blow your lid
being directly honest with your opinion may not make you well liked but it will get you appreciated by the worthwhile few with the sense to understand.... Id rather be appreciated for who I am than liked for what I'm not.
#4 demented
demented
Posted 24 May 2014 - 05:23 PM
Yes, I most certainly did but as I've never experienced such an issues, wasn't so obviously to me.
I also believed, when heater matrix does leaks, it tends to leak into passenger footwell ?
#5 JC
Posted 24 May 2014 - 08:10 PM
i'll have another look, it doesn't have a sunroof and heater matrix is the other side....
#6 shifty
shifty
  • Drives:RS Turbo & MK6 Si
Posted 24 May 2014 - 08:44 PM
The heater matrix in my old MK6 soaked the passenger footwell!
  • Escort Si-130 likes this
#7 shawdreamer
shawdreamer
Posted 25 May 2014 - 12:50 AM
a Gti I did some work on dumped its matrix wad in both its footwells, on that occassion the drivers side was by far the most "squishy" underfoot.
you could have happily grown grass in there.......... which now gives me a a rather funny idea for a mod :))
  • scottybo and mikeypr1 like this
#8 Escort Si-130
Escort Si-130
  • Drives:Escort mk5b Cabriolet
Posted 27 May 2014 - 11:10 AM
Could also be the sills blocked up with mud. I used to stick a coat hanger end or small screwdriver to clear them. Also when I remover the inner wing liners always cleared the mud crap build up in there.
Heater matrix usually leaks onto the nearside.
94' Escort Si Convertable - Imperial Blue, RS2000 16v
#9 sidrick
sidrick
  • Gender:Not Telling
Posted 27 May 2014 - 11:26 AM
Damp patch, eh?
Coach-Mick-Mcarthy-Look-at-Camera-Smile.
  • JC and co-op scooby like this
#10 scottybo
scottybo
  • Drives:2.0l ford escort finnesse. Bmw 318i 2.0l se touring. Mk3 mondeo 2.2l ST tdci
Posted 27 May 2014 - 02:42 PM
 indoor garden?
  • mikeypr1 likes this
Ever noticed that putting "anal" in front of some ford model names makes them sound funny? Fiesta, Probe, Ranger. Explorer, Maverick etc... lol
#11 JC
Posted 27 May 2014 - 08:41 PM
where about does one clear the sills? The wing liners were removed about 6mths ago and cleared, and the car hasn't been used too much since....
thanks for your reply :-)
#12 hux19
hux19
  • Drives:1.8 escort mk6
Posted 09 June 2014 - 10:16 AM
Can i ask have you had the trim off the drivers door?
I had a leak on the drivers side and it turn out to be the plastic sheet stuck behind the door trim wasn't stuck to the door properly.
The water was running down inside the door as its was suppose to but then it would run between the door card and metal at the bottom of the door instead of out the drain holes.
It would then run over the door sill and into the foot well.
  • JC likes this
#13 mikeypr1
mikeypr1
  • Drives:escort 1.8 si
Posted 13 June 2014 - 10:05 AM
I had a mk3 that had grass growing in the footwells  got to a point where I had to mow it every two weeks :roll: cant get more eco friendly than that. :thumb:
#14 JC
Posted 13 June 2014 - 10:06 PM
Good point i'll check that too, cheers
