MK6 Escort Cooling Fan Switch Problem
Escort cooling fan temp sensor cooling problem
1 reply to this topic
#1 mk6escort
mk6escort
  • Drives:MK6 Escort Encore
Posted 15 August 2017 - 06:52 PM
Hi all, new to all this so please be nice :)
right i have a MK6 Escort Encore.... was a Auto now a Manual, all changed over and starts with the key aswell but the issue i have is the fact my car wants to over heat......
i got brand new thermostat, and the 2 sensors that go into the housing are brand new from Fords, so now i can see how hot my car is getting. but the the top sensor (Fan Switch) seems to be working as ive tested it all the a multi-meter but no matter how hot the car gets the fan wont kick in...... UNTIL i take the connector off the sensor wait about 10 seconds and the fan kicks in........ soon as i put the plug back on the sensor the fun cuts out again....... really confused on what to do next......
ive changed the relay aswell and still the same and ive tested them and the relays are working as they should
ANY HELP WOULD BE AMAZING!!
Thanks!
#2 davec
davec
  • Drives:Escort 1.8 si
Posted 18 August 2017 - 07:05 PM
Usually when the fan doesn't kick in you disconnect the switch,short it out with a piece of wire and see if that runs the fan.This proves if the switch is faulty.I can't see how the fan runs when you disconnect the wiring off the sensor.
Was this fault on the car before the auto to manual change?l
Also tagged with one or more of these keywords: Escort, cooling fan, temp sensor, cooling problem
