wwwd Posted February 13, 2008 Share Posted February 13, 2008 I stupidly bought some aluminium valve caps for my tyres (as my old ones were f*cked) and I've tried to remove them today but they seem to be welded on or something! I've even tried getting them off with a pair of pliers, but it just turns the cap along with the valve tube! Any ideas how to get these f*ckers off?! I need to sort out my tyre pressures! Link to comment Share on other sites More sharing options...
Danny1107 Posted February 13, 2008 Share Posted February 13, 2008 get some grips on the valve then some pliers on the valve cap happend with me a few times, stick a little copper grease on the threads when you refit them Link to comment Share on other sites More sharing options...
wwwd Posted February 13, 2008 Author Share Posted February 13, 2008 get some grips on the valve then some pliers on the valve cap happend with me a few times, stick a little copper grease on the threads when you refit themI've been using pliers and the valve has been turning with the cap - can I actually wreck the tyre by turning the valve too much (and somehow cause a puncture?) And what grips did you use on the valve mate? Link to comment Share on other sites More sharing options...
Danny1107 Posted February 13, 2008 Share Posted February 13, 2008 i just used some long nose pliers on the valve its self and mole grips on the valve cap its pretty hard to pull a valve out with pliers, its hard enough with a valve puller thats why most tyre fitters cut them out when putting new ones in you wont get an air leak unless you rip the rubber round the valve to bits Link to comment Share on other sites More sharing options...
bluliz Posted February 13, 2008 Share Posted February 13, 2008 The valve cap has correded to the brass of the valve. Well i think they are brass. You could try a bit of heat on the cap....failing that dremel then off. Or twist like hell on them....however i'd only do that park outside a tyre fitters. Link to comment Share on other sites More sharing options...
Sedgie07 Posted February 13, 2008 Share Posted February 13, 2008 this happened to me, needed a new valve in the end Link to comment Share on other sites More sharing options...
wwwd Posted February 13, 2008 Author Share Posted February 13, 2008 Thanks guys. Well I've finally managed to get them off! Had to get two pairs of pliers and hold down the valve while using the other one to twist the valve cap off - as bluliz said they had bloody fused themselves to the valve! Put the rubber ones back on now so happy days. I did damage the rubber bit of the valve tube though - how long will it take to know if I've actually f*cked up the tyre? (i.e. how long will it take to go flat?) Edit: Just checked and some of the metal bit (on the outside of the tube, under the rubber) is slightly damaged too! Link to comment Share on other sites More sharing options...
Danny1107 Posted February 13, 2008 Share Posted February 13, 2008 Thanks guys. Well I've finally managed to get them off! Had to get two pairs of pliers and hold down the valve while using the other one to twist the valve cap off - as bluliz said they had bloody fused themselves to the valve! Put the rubber ones back on now so happy days. I did damage the rubber bit of the valve tube though - how long will it take to know if I've actually f*cked up the tyre? (i.e. how long will it take to go flat?) Edit: Just checked and some of the metal bit (on the outside of the tube, under the rubber) is slightly damaged too! pour abit of water on there see if any air is coming out, if not you should be fine, will only cost about £1-3 each wheel for a new valve, if you buy some of the bolt in metal valve they look better and metal valve caps don't seize to them they cost about £8 to £20 depends on make and where you get them from, will cost about £5 to get them fitted at most tyre fitters Link to comment Share on other sites More sharing options...
drakeuk Posted February 13, 2008 Share Posted February 13, 2008 you hould of parked it out side my house, they would of been off in no time, all the little s*@ts round here have got chrome valve caps on there bikes, at least 3 sets off them were mine, Link to comment Share on other sites More sharing options...
cash21289 Posted February 14, 2008 Share Posted February 14, 2008 lockwood sell theft proof ones about 20 quid quite expensive to start with but they will never get nicked a* product only come off with a special key, well made as alwys with lockwood sell at motorworld Link to comment Share on other sites More sharing options...
bluliz Posted February 14, 2008 Share Posted February 14, 2008 lockwood sell theft proof ones about 20 quid quite expensive to start with but they will never get nicked a* product only come off with a special key, well made as alwys with lockwood sell at motorworld Special key? you mean an Allen key..... Link to comment Share on other sites More sharing options...
PeeWee Posted February 14, 2008 Share Posted February 14, 2008 lockwood sell theft proof ones about 20 quid quite expensive to start with but they will never get nicked a* product only come off with a special key, well made as alwys with lockwood sell at motorworld Special key? you mean an Allen key..... Nah! iirc rob the cap just spins round if you try to remove in unless you use the provided key that locks it in place letting the actual cap move. Link to comment Share on other sites More sharing options...
wwwd Posted February 15, 2008 Author Share Posted February 15, 2008 you hould of parked it out side my house, they would of been off in no time, all the little s*@ts round here have got chrome valve caps on there bikes, at least 3 sets off them were mine,They would of had problems getting mine off mate! The tyres are still inflated anyway so it's all good! Link to comment Share on other sites More sharing options...
DJ Posted February 15, 2008 Share Posted February 15, 2008 had the same problem only 2 days ago, i sprayed a load of WD40 on them and left them overnight and tried again the next morning with pliers and grippers and they came off quite easy. be careful not to tear the rubber,good luck. Link to comment Share on other sites More sharing options...
reid Posted February 15, 2008 Share Posted February 15, 2008 ive got flush fit valves on mine, looks prety good but your in shite street if you lose the wee valve extension. Link to comment Share on other sites More sharing options...
