TommyT Posted May 2, 2008 Share Posted May 2, 2008 I took my maf and air filter off today and found the maf and air intake pipe to be covered in oil from the breather pipe that comes out the top of the rocker cover. The car use to have a ecotech valve thingy on there when i got it and it never had this problem, since removing it, the pipe just fills with oil and is putting it all back into the system. Is it normal to have this much and would i be better off with replacing some sort of filter to reduce the flow? Link to comment Share on other sites More sharing options...
Craig855S Posted May 2, 2008 Share Posted May 2, 2008 think u have a blockage somewhere forcing oil to come out the breather.the oil that comes from the rocker cover goes into the bottom of the airbox into a little foam area.put new foam in the thing but i reckon u have a more seriosu problem Link to comment Share on other sites More sharing options...
TommyT Posted May 2, 2008 Author Share Posted May 2, 2008 It's a cone filter so it's just going straight into the MAF. how can i find where a blockage is or is it a job for a garage? Link to comment Share on other sites More sharing options...
madaboutescorts Posted May 2, 2008 Share Posted May 2, 2008 It's a cone filter so it's just going straight into the MAF. how can i find where a blockage is or is it a job for a garage? av u changed ur rocker cover at all, ....... Link to comment Share on other sites More sharing options...
TommyT Posted May 2, 2008 Author Share Posted May 2, 2008 Yes, did it a few months ago, just before all this started. I can see this going somewhere.....please go on. Link to comment Share on other sites More sharing options...
madaboutescorts Posted May 2, 2008 Share Posted May 2, 2008 Yes, did it a few months ago, just before all this started. I can see this going somewhere.....please go on. when you changed ur rocker cover did you change,the little plate inside the rocker cover,, cause if you did'nt it will force oil out as well as air, it aint a problem tho, all you need to do is take ur rocker cover back off and put the plate back on ( if you still got ur old rocker cover) Link to comment Share on other sites More sharing options...
TommyT Posted May 3, 2008 Author Share Posted May 3, 2008 (edited) Yes, did it a few months ago, just before all this started. I can see this going somewhere.....please go on. when you changed ur rocker cover did you change,the little plate inside the rocker cover,, cause if you did'nt it will force oil out as well as air, it aint a problem tho, all you need to do is take ur rocker cover back off and put the plate back on ( if you still got ur old rocker cover) The only thing i changed is the gasket. where is the plate located please. Thanks very much edit: think i just found it on my old one. Like a shield typw thing going across that half of the rocker cover?? Edited May 3, 2008 by TommyT Link to comment Share on other sites More sharing options...
Craig855S Posted May 3, 2008 Share Posted May 3, 2008 yep make sure ur rocker has that sheild Link to comment Share on other sites More sharing options...
TommyT Posted May 3, 2008 Author Share Posted May 3, 2008 It didn't berfore but all sorted now. Thanks for the help madabout escorts and scoop. Explains alot lol Link to comment Share on other sites More sharing options...
madaboutescorts Posted May 3, 2008 Share Posted May 3, 2008 It didn't berfore but all sorted now. Thanks for the help madabout escorts and scoop. Explains alot lol no probz m8 Link to comment Share on other sites More sharing options...
