cleaning lambda sensor
Welshy_Pete
Hello can there be any way of cleaning lambda sensors at all if so what can you use thats fine and causes no damge? :P
Just not heard any body say about this before cause they can soon get coverd up in soot carbon :D
afaik your not even supposed to touch the actual sensor end in any form, neveermind cleaning it....
....begs the question tho.............why?
Just thought would ask about it cause not heard anybody mension about it before :thumb:
sorry stu but i must disagree in 13 years of repairing cars that fail mot's because of a faulty lambda sensor 50% of the time cleaning it with a wire wheel will correct a incorrect signal from a lambda sensor
Considering the element that measures anything is deep inside the sensor where you can't get to it, then I doubt that greatly.
this only my own personal experience and i am not trying to start a argument but this dose work and has been proven from the readings on a sun scope and snapon cat tester both calibrated when thet should be.
speedy yes quick fix and will work (i've not done that since a fiesta let me see its con rod)
