head gasket or water pump-or other!
rogerthecabbyboy
basically i put a new temp sender unit in because the one i had was duff and erratic, and replaced the stat at the same time. now i can actually keep an (accurate-ish) eye on the temp when i accelerate hard the temp rises a letter on the scale and then as i'm up to speed it drops back to its usual position. i'm guessing this isn't normal as this is what my last engine did just before the h/g let go and oil turned to a gooey mess. under normal driving the temp is fairly stable although it does fluctuate a bit.
the oil looks ok as its fresh 3 weeks ago, and the coolant fresh as of a couple of days ago.
help on what it could be?
