brakes
richie_mk5
did you have a lot of fluid in the reservoir? if you didn't then air will be in the system. make sure you over fill the reservoir when bleeding and keep it topped up during the process. and on the last bleeding don't top it up at all and use as much fluid as you need then when you done the complete system again fill to max! and the bleeding be from passenger front - driver rear - driver front - passenger rear? thats what the haynes manual says!
how did you bleed them ??
i used this contraption it pushed flued throught the sistom its called eazi bleed
it is front right back left front left back right
That's exactly how I bleed my brakes with the Easy Bleed. As far as I can remember, that sequence is correct. So just try it a few times over and over again.
You'll get there in the end!
