deano1978 Posted May 9, 2008 Share Posted May 9, 2008 hi i have bought some led bulbs for the dash dials which are green do the bulbs just unscrew like the clock or do they take more work???? Any help? Thanks Link to comment Share on other sites More sharing options...
SLEEMAN Posted May 10, 2008 Share Posted May 10, 2008 the main lighting in the clocks comes from two bulbs on the top on the clock set. and yes they twist screw on and off. and what type of l.e.d's have you got i bought some on ebay and they were the proper ones which included the twist fit bulb holders. which was a bonus! Link to comment Share on other sites More sharing options...
mrmetallica Posted May 10, 2008 Share Posted May 10, 2008 hi i have bought some led bulbs for the dash dials which are green do the bulbs just unscrew like the clock or do they take more work???? Any help? Thanks the dash dial bulbs arnt green.theirs a green plastic strip in front of the bulbs.if you want different colour you have to take green strip away. Link to comment Share on other sites More sharing options...
1pukkadeal Posted May 10, 2008 Share Posted May 10, 2008 the dash dial bulbs arnt green.theirs a green plastic strip in front of the bulbs.if you want different colour you have to take green strip away. Spot on Link to comment Share on other sites More sharing options...
lairdie Posted May 11, 2008 Share Posted May 11, 2008 if you change the heater control bulbs they still show green. i put blue leds and the temp is the only bit that shows blue going to split it open to see if it can be altered inside Link to comment Share on other sites More sharing options...
mrmetallica Posted May 11, 2008 Share Posted May 11, 2008 if you change the heater control bulbs they still show green. i put blue leds and the temp is the only bit that shows blue going to split it open to see if it can be altered inside its the black covering on the out side.it has green under it in places.i spoted these on ebay with the blue and red light shinnin through £15.99. Link to comment Share on other sites More sharing options...
lairdie Posted May 11, 2008 Share Posted May 11, 2008 if you change the heater control bulbs they still show green. i put blue leds and the temp is the only bit that shows blue going to split it open to see if it can be altered inside its the black covering on the out side.it has green under it in places.i spoted these on ebay with the blue and red light shinnin through £15.99.could you post a link? thanks Link to comment Share on other sites More sharing options...
Drax Posted May 12, 2008 Share Posted May 12, 2008 yeh i bought them the other day, aint fitted em yet. the dash one you can do yourself but it means taking the dials out which was a cock for me! Link to comment Share on other sites More sharing options...
mrmetallica Posted May 12, 2008 Share Posted May 12, 2008 (edited) if you change the heater control bulbs they still show green. i put blue leds and the temp is the only bit that shows blue going to split it open to see if it can be altered inside its the black covering on the out side.it has green under it in places.i spoted these on ebay with the blue and red light shinnin through £15.99.could you post a link? thanks hope this works http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...A:IT&ih=002 it does Edited May 12, 2008 by mrmetallica Link to comment Share on other sites More sharing options...
deano1978 Posted May 14, 2008 Author Share Posted May 14, 2008 Right the bulbs they have sent me which apparently fit the dash a push in led, am i being thick is there a way of fitting them i thought the dash took twist 509t led but what has been sent is push in. HELP!!!!!! Link to comment Share on other sites More sharing options...
1pukkadeal Posted May 14, 2008 Share Posted May 14, 2008 (edited) Right the bulbs they have sent me which apparently fit the dash a push in led, am i being thick is there a way of fitting them i thought the dash took twist 509t led but what has been sent is push in. HELP!!!!!! the heater panel should use type 286 and the main dash cluster push fit 501 type into the original holder Edited May 14, 2008 by 1pukkadeal Link to comment Share on other sites More sharing options...
deano1978 Posted May 14, 2008 Author Share Posted May 14, 2008 Right the bulbs they have sent me which apparently fit the dash a push in led, am i being thick is there a way of fitting them i thought the dash took twist 509t led but what has been sent is push in. HELP!!!!!! the heater panel should use type 286 and the main dash cluster push fit 501 type into the original holder The 501 bulb is too big to push fit into the original holder well the ones they sent me anyway, getting fucked off now. Link to comment Share on other sites More sharing options...
lairdie Posted May 23, 2008 Share Posted May 23, 2008 (edited) Right the bulbs they have sent me which apparently fit the dash a push in led, am i being thick is there a way of fitting them i thought the dash took twist 509t led but what has been sent is push in. HELP!!!!!! the heater panel should use type 286 and the main dash cluster push fit 501 type into the original holder The 501 bulb is too big to push fit into the original holder well the ones they sent me anyway, getting fucked off now.post some pics dont know what you meanhave you tried crazy leds on ebay Edited May 23, 2008 by lairdie Link to comment Share on other sites More sharing options...
