Alarm key and lock problem
skydivebaz
did this key ever work that lock before,as any ford key will lock the car but only the correct key will unlock it,as some people change the barrels from other cars and if you are certain it did work before try squirting the good old wd-40 in the barrel as it may be clogged up with crap Edited by 1pukkadeal
sounds like the key has worn aswell, unless you,ve got another key to try it with to rule it out?
yeh im thinking key also. but i works in the ignition fine and sometimes the boot and as the norm only got one key, but it is slightly twisted so going to get a non chipped key cut to test if it works the locks.
