Help With Doors
tdonnelly3
hello all, my drivers door lock has been playing up for a couple of weeks, will lock but not unlock, anyone got any tips on changing this for the passenger side lock, how easy is it to do?
also went to get out the car before work (half hour ago) and the door wouldnt open from the inside, little handle just does nothing, is this maybe just a rod or wire inside that needs hooked back on???
all help greatly appreciated
pretty sure lock swap wont work your key could just be worn or crap inside the lock try a bit of wd 40 first ,you could have a sticky solonoid if not opening or even handle cable unclipped ,just remove the little cover from the handle surround and check and see if the cable is attached to the handle itself Edited by 1pukkadeal
