Posted July 19, 200816 yr right my blowers work on 1 and 2 and seem to stop working on 3 or go to the speed of 1 ive changed the switch and resistor pack with no luck! checked all fuses the one on the fuse box anyway! any one know what the problem is? im thinking it could be the motor now! but im sure it will be a bitch to change and don't want to do it if it not the problem
July 20, 200816 yr I really doubt that its the motor as its working on other speeds ,the resister pack would be my first port of call,but if you have changed that ,I would then investigate the fuse box as I have come accross this before on the mk5 and mk5b models Edited July 20, 200816 yr by 1pukkadeal
July 20, 200816 yr Author what am i looking for? the switch is the air con model but i changed that anyways and also the resistor pack! its a but unlikley that 3 resistor packs would have the same problem! or is it?
July 20, 200816 yr what am i looking for? the switch is the air con model but i changed that anyways and also the resistor pack! its a but unlikley that 3 resistor packs would have the same problem! or is it? be really bad luck with 3 faulty resistor packs ,it could be the live feed wire for that speed from the fusebox ,have you tried a different speed selector switch too
July 20, 200816 yr Author yea i got 2 switches from my local yard the other day and it still not working prop. there is an lx escort in the yard with a 97 fuse box but mine is a 96 will that make a diff?
July 20, 200816 yr yea i got 2 switches from my local yard the other day and it still not working prop. there is an lx escort in the yard with a 97 fuse box but mine is a 96 will that make a diff? should be a code on your fusebox ,unfortunately without seeing the car its all guesswork and a process of illimination
July 20, 200816 yr Author cheers for the reply and helping getting to the bottom of this! the fuses on the one at the scrap yard are in diff positions so i left it as i think i didnt work! the code on my fuse box is something like 96ago7fgfgf and the one at the yard is 97 something
July 20, 200816 yr cheers for the reply and helping getting to the bottom of this! the fuses on the one at the scrap yard are in diff positions so i left it as i think i didnt work! the code on my fuse box is something like 96ago7fgfgf and the one at the yard is 97 something always worth asking heavyrightfoot off here as he a top bloke and often has a selection of them for sale
