Posted July 21, 200816 yr i want to fit a oil temp guage to my zetec-se 1.6. has any body done this and where did you put the sensor and how?????
July 23, 200816 yr Sandwhich plate between the oil filter and the sump. Then a sensor goes into the plate as well as a pressure one if you want. Thats the easiest/most convenient way but you can also do it with a t-piece aswell. Can get all bits off flea bay!!
July 25, 200816 yr Author the dial i was looking at comes with a small screw type thing, is there a sandwhich plate alreay on the filter to do this?
