eldarto Posted November 1, 2008 Share Posted November 1, 2008 Right i want to spruce up my engine bay and i thought i would start with the rocker/cam cover by spraying it. Do i have to use the (limited in colour) engine laquers that so many places sell or is there another route i can take to gat my own unique colour? Basically i need to protect the finish from heat but not too sure how to do it without using the special heat resistant paint. Has anybody done this? or had it done? or know how its done. please help!!! Link to comment Share on other sites More sharing options...
Danny1107 Posted November 1, 2008 Share Posted November 1, 2008 any paint will be fine, i used hycote primer and paint on mine, make sure you clean it well first Link to comment Share on other sites More sharing options...
eldarto Posted November 1, 2008 Author Share Posted November 1, 2008 Sweet, thats what i wanted to hear. What do you recommend to clean it? Link to comment Share on other sites More sharing options...
Ryoishikawa Posted November 1, 2008 Share Posted November 1, 2008 a wire brush or ur tooth brush lol Link to comment Share on other sites More sharing options...
eldarto Posted November 2, 2008 Author Share Posted November 2, 2008 a wire brush or ur tooth brush lol My toothbrush is reserved for the toilet rim so it will have to be the wire brush What i meant was any chemicals recommended other than degreaser, etc? Link to comment Share on other sites More sharing options...
Tez162003 Posted November 2, 2008 Share Posted November 2, 2008 i just use a wire brush tool on an angle grinder, then washing up liquid to get any exess grease of Link to comment Share on other sites More sharing options...
Danny1107 Posted November 2, 2008 Share Posted November 2, 2008 wire brush and thinners is what i used Link to comment Share on other sites More sharing options...
Tez162003 Posted November 2, 2008 Share Posted November 2, 2008 tell a lie, my current one is simply sand blasteded and powder coated Link to comment Share on other sites More sharing options...
hicksy Posted November 2, 2008 Share Posted November 2, 2008 I used some gunk to get rid of the oil then a wire brush, then some emery paper, then primed it with halfords primer......then emeryed it again, then primed a few more times, the halfords amparo blue(a few coats) then some silver paint on the embossed lettering. Then a couple of coats of halfords lacquer. Its been good for about a year so far Link to comment Share on other sites More sharing options...
eldarto Posted November 10, 2008 Author Share Posted November 10, 2008 Cheers guys, some great help here. My mate said brake cleaner is good for getting gunk off, is this true? as i've never really cleaned/looked after my engine bay before and want to do it properly. Link to comment Share on other sites More sharing options...
cherrybeard Posted November 11, 2008 Share Posted November 11, 2008 I found brake cleaner to work better than gunk. The final clean should be soapy water finished off with clean water. If you use wire wool, make absolutely sure that all traces are removed from underneath the rocker cover before you fit it back. Take off the baffle plate as well and get rid of any remnants of it there too. Also, do as the others have said and make sure you use an aluminium primer. How did you all deal with the groove that gets rubbed into the metal from the throttle cable? Was thinking about using a special metal filler but got no experience of these yet. Link to comment Share on other sites More sharing options...
eldarto Posted November 11, 2008 Author Share Posted November 11, 2008 How did you all deal with the groove that gets rubbed into the metal from the throttle cable? Was thinking about using a special metal filler but got no experience of these yet. Hey you stole my next question!!! You gotta love Ford though "I can't think of how to mount this bit of cable properly, out of the way, that stops it from rubbing on any other component.... F*** it i'll just put it here. That should save a few pennies and keep the bean counters happy" Link to comment Share on other sites More sharing options...
