Indicators flash when double locking
EssexMikeSi
I just wondered if its a case of a relay needing to just be plugged in or something. My old 98R Gti would flash them when u double locked it, yet my current R reg si doesnt do this. Just wondered if anyones found the same. My mates gti doesnt flash either. My gti had no upgraded alarm or anything on it though. :unsure: Edited by EssexMikeSi
  • Replies 31
mine flashes,
up to one month ago it only flashed when locked from drivers side but not on passenger side (also caused a my ford RCL not to work), so after alot of searching I found out that the passenger door lock sensor was buggered, so I replaced that and now the RCL works! (woohoo) and flashes when locked from both sides.
If it doesnt flash its cos your relays arent fitted......
Use two small brown relays (same as your headlight relays)
And fit them in the cradle sat on inner wing behind drivers side kick panel.
If you only fit one you can make it so either drivers side or kerbside indicators flash :)
I found it by trial and error and wrote about it ages ago :)
oh and yeah escortNregs flash cos thats the car I did it to :)
