Posted September 30, 200915 yr Does the escort make the beep noise when you lock the car,alarm it? Mine use to but not anymore,not sure if it was my gti auto alarm that was doing it or the ford alarm.
September 30, 200915 yr Author OK, mine did but over the years it stopped,then when the siren on the gti auto alarm wouldnt shut up 1 night,i had to rip it out so wasn't sure which 1 was bleeping,does any escort alarm do it?
September 30, 200915 yr me either , they flash when u double lock the car  Mine doesn't?Is that when you lock then half turn the key again & it whirs?
September 30, 200915 yr dont even have to lock and unlock and lock again , you can just turn the key to the left then lock it as normal and does the same thing unless mines had the extra relay fitted to flash
October 1, 200915 yr Author Had a google,looks like it was the siren that makes the beep.Since I've ripped mine out,explains why its not doing it any more.Worked for ages then stopped,then about a year later 1 night couldn't shut the siren up so ripped the tw*t out.Looks like water has been getting in the siren and did it in.
October 6, 200915 yr yeh my escort does this . if its been sat in the garage for months, i think its when the battery is low because i charge the battery up and doesnt do it again untill it goes nearly flat again.
October 7, 200915 yr Author yeh my escort does this . if its been sat in the garage for months, i think its when the battery is low because i charge the battery up and doesnt do it again untill it goes nearly flat again. Its the alarm on mine that did do it,not the battery.These new cars now when you walk past and the guy opens it with the fob it beeps twice,mine worked for years when il'd open the car it would beep twice and the lights flashed,doesn't work now like i said ripped the siren out.
