Posted October 1, 200915 yr I have a 1992 Ford Escort XR3i which needs a rear disc hub as the wheel bearings have shot the hub to pieces. Its at present stranded in my mechanics garage and has been for the past 3 weeks. Been to nearly all breakers yards but not found one. Apparently any Ford Escort or Orion from 1990 onwards that has rear discs would work. Main Ford Dealers say its discontinued so cant even buy a new one apparently its rare. They only made this car for a couple of years. If I cant find one I'll have to scrap it and its too good for that. It has an RS200 kit i.e. bonnet, skirt, leather seats etc.PLEASE HELP!
October 1, 200915 yr Author I have a complete rear setup inc hubs £120 Are they off an escort with rear discs from year 1990 onwards. Its definitely the rear hub bearing carrier you have for a Mk 5 Escort ?
October 1, 200915 yr I have a complete rear setup inc hubs £120 Are they off an escort with rear discs from year 1990 onwards. Its definitely the rear hub bearing carrier you have for a Mk 5 Escort ? if its the rear setup it should be beam, hubs and probably discs and callipers too? the disc beam was fitted on some of the 130 spec cabbies and mk5 and some mk6 rs2000's as far as i know
