Posted October 2, 200915 yr is the above easy to do or nor, is it a straight swap if not whats needed and would it just be easyier to get another EFi engine cheers Callum
October 2, 200915 yr ecu, engine loom, pats sensor & key, engine, airbox and pipes, modify fuel lines, change brake vacuum pipe and away you go if i remember rightly!
October 3, 200915 yr Author many many miles without a service for a very long time, so shes getting old and tapetty
October 5, 200915 yr many many miles without a service for a very long time, so shes getting old and tapetty Just give it a good service these things can go forever lol.
October 5, 200915 yr Your swapping from 1.8 zetec to another 1.8 zetec yes?? What car is it?? You shouldnt have to bother with any looms/pats or all that gash
October 6, 200915 yr Author its a 1.8 EFi Si hatchback, and i think its gone too far to be fixed with a service
October 6, 200915 yr All you need is another 1.8 zetec, just make sure you get the correct starter position, yours will be at the back. Its a straight swap, in and out in 2 hrs. No extra bits needed.
October 6, 200915 yr I still want to know what a 'normal' 1.8 engine is? As opposed to there being a dif kind??
