Posted October 15, 200915 yr Both my windows dont go up properly when they get to the top they both seem to tilt a little bit then i have to push the front of the glass up a bit for them to shut properly i have grease everything i put shed loads of wd40 down the runners i thought it might of been the door window rubbers themselves so i got new ones and the same thing happened ...I have just noticed there is a bit of play (quite a bit of play actually) in the centre where the two screws go to hold the window on to the regulator itself there are some yellow plastic bits that run up a white runner in the middle the window rocks from side to side is this right should they rock a bit or are the shitty little yellow plastic bits worn Cheers in advance
October 16, 200915 yr probably the actual runners or bits you've mentioned are knacked. shouldnt be a huge drama to remedy
