October 18, 200915 yr remove inner trim undo 3 x 8mm bolts = hey presto Edited October 18, 200915 yr by RDS6006
October 18, 200915 yr Author remove inner trim undo 3 x 8mm bolts = hey presto hey yeah feel little stupid now lol.... i already had the trim of and the first bolt out, but i didnt realise you have to really force the plastic clips off from the other side... anyway done it now cheers..
October 18, 200915 yr The "inner trim" is the bit with the little knob on to adjust non-electric mirrors? will that just pull/pop off ?
October 18, 200915 yr The "inner trim" is the bit with the little knob on to adjust non-electric mirrors? will that just pull/pop off ? door card has to come off to remove the screw then just prise it off
October 18, 200915 yr the inner trim - non electric: you need to take the interior door panel off, and there is a small screw - they remove the ring that is on the adjuster, then the panel will just prise off. electric: you need to take the interior door panel off, and there is a small screw, then the panel will just prise off.
