rebellious Posted January 30, 2010 Share Posted January 30, 2010 evening all, just a quick question, what spacing is required to fit mondeo front calipers, discs and pads on my shed? is it 3mm? Link to comment Share on other sites More sharing options...
dutchkev Posted January 30, 2010 Share Posted January 30, 2010 do you mean the 300mm conversion? Escort brake upgrade guide try that - all covered in there Link to comment Share on other sites More sharing options...
scottg17 Posted January 30, 2010 Share Posted January 30, 2010 this any use to ya http://www.escortevolution.co.uk/forums/in...howtopic=113463 Link to comment Share on other sites More sharing options...
rebellious Posted January 30, 2010 Author Share Posted January 30, 2010 unforunaltly my pockets arent deep enough for the 278mm+ convertion, ive been given calipers off a mk2 2.0 (260mm jobbies), and wanted to fit them, as ive got brand new discs and pads sat here and the 1600 brakes im currently using are struggling and getting tierd? Link to comment Share on other sites More sharing options...
dutchkev Posted January 30, 2010 Share Posted January 30, 2010 260mm? youll need escort rs2000 set up. the disks and callipers on an escorts rs2000 are 260mm and a straight swap from the 240mm jobbies Link to comment Share on other sites More sharing options...
rebellious Posted January 31, 2010 Author Share Posted January 31, 2010 this mean the mondy ones wont fit at all? Link to comment Share on other sites More sharing options...
rebellious Posted February 1, 2010 Author Share Posted February 1, 2010 sorry have i not got enough money to warrent an answer on this topic or something? Link to comment Share on other sites More sharing options...
dutchkev Posted February 1, 2010 Share Posted February 1, 2010 paitence is a virtue were not all sat here 24/7 waiting for a post in answer to your question - no, the mondeo callipers are usless - unless you wanted a paper weight. if you want to upgrade to 260mm brakes then ypu'll have to use the escoer rs2000 disks and callipers Link to comment Share on other sites More sharing options...
Stu Posted February 1, 2010 Share Posted February 1, 2010 in answer to your question - no, the mondeo callipers are usless - unless you wanted a paper weight. What problems did you have when trying to fit these Mondeo calipers? Also, rebellious: Demanding answers on a forum will only end up with you upset, so please be nice. Link to comment Share on other sites More sharing options...
Danzetec Posted February 2, 2010 Share Posted February 2, 2010 3mm spacers will bring you in line, you will want the mondeo hoses too I think tho Link to comment Share on other sites More sharing options...
cabbykarl Posted February 2, 2010 Share Posted February 2, 2010 Mondeo calipers and rs2000 discs working fine on my mk5. Just spaced them out as above, used the mondeo hoses and changed the pipe union to suit. Link to comment Share on other sites More sharing options...
stevmo3691 Posted February 2, 2010 Share Posted February 2, 2010 i was going to use 260mm mondeo brakes on mine. you do need to make the bolt holes in the hub bigger as mondeo carrier uses bigger bolts and mondeo hose as has different part going into calliper than escort ones. i managed to get RS2000 ones cheap so will be using them instead. Link to comment Share on other sites More sharing options...
cabbykarl Posted February 2, 2010 Share Posted February 2, 2010 Oh yeah forgot about drilling the hub bolt holes out a bit....was a while ago.. Link to comment Share on other sites More sharing options...
fizzwhizz Posted February 3, 2010 Share Posted February 3, 2010 Just to make sure,, but Is it Mk1 calipers that you can use with this conversion ?? we av a mk1 mondy V6 st24 sittin in local scrappy, sat there with all its bits on still cheers Link to comment Share on other sites More sharing options...
stevmo3691 Posted February 3, 2010 Share Posted February 3, 2010 Just to make sure,, but Is it Mk1 calipers that you can use with this conversion ?? we av a mk1 mondy V6 st24 sittin in local scrappy, sat there with all its bits on still cheers you can use any mondy ones if your willing to try. also that would be a mk2 (mk1 93-96, mk2 96-00) as ST24 wasnt till mk2, but thats one i have heard of a few times as ST24 use bigger brakes than the 1.6, 1.8, 2.0 and TD ( i have the ones off those with un-used discs and pads in my garage) Link to comment Share on other sites More sharing options...
