ScORTED Posted February 4, 2010 Share Posted February 4, 2010 you can't use mondeo discs whatever you do, so for the 2.0 non 4wd etc use 260mm escort rs2000 discs and space the calipers a fewmm and drill the hub out as per the 300mm guide. the 4wd mondeo and earlier v6 models pre mk3 use the same calipers as the escort/sierra cosworth, these fit the same way as previously mentioned abovebut again you can't use the mondeo discs, use the escort cosworth ones. hope this helps Link to comment Share on other sites More sharing options...
