Brylt Posted January 30, 2010 Share Posted January 30, 2010 The oil light on the 1.6 zetec spends more time on than off so i could do with some info please.Now the last time i had any problems like this was when i had a few cvh escorts which used to block the pickup pipe solid which was a common fault, do the zetec engines suffer the same sort of fault, where abouts is the oil pump, are these known for failing? also the revs take their time to drop when you lift off to change gear, could this be related to the oil problem or something totaly different.The engine sounds ok but does have a slight rattle sometimes which indicates the oil light on is not a faulty switch and the mileage is 276000 so could the engine just be worn out. Thanks Bryan Link to comment Share on other sites More sharing options...
dutchkev Posted January 30, 2010 Share Posted January 30, 2010 have you checked the oil level - daft question but start with the basics Link to comment Share on other sites More sharing options...
Stu Posted January 30, 2010 Share Posted January 30, 2010 After the above, you'll need to be checking the oil pressure with a proper gauge. Link to comment Share on other sites More sharing options...
escort4x4 Posted January 30, 2010 Share Posted January 30, 2010 As said it could be one of many things, oil pressure very lowlow oilblocked pick up pipeor even the oil pressure switch But as stu said your best having the pressure tested, as if it is a pressure fault you could destroy the engine very very quicklu Link to comment Share on other sites More sharing options...
Brylt Posted January 30, 2010 Author Share Posted January 30, 2010 The oil level is fine and the top end has an intermitent rattle indicating limited oil, how do i check the oil presure, is it a specialist tool or is there a more basic way to test it. Bryan Link to comment Share on other sites More sharing options...
Stu Posted January 30, 2010 Share Posted January 30, 2010 You need an oil pressure gauge and fittings to connect to the place where your oil pressure switch goes. Link to comment Share on other sites More sharing options...
cdf_scort Posted January 30, 2010 Share Posted January 30, 2010 i had this and found out it was a fault pressure switch Link to comment Share on other sites More sharing options...
Brylt Posted January 31, 2010 Author Share Posted January 31, 2010 Getting hold of a pressure tester through the week so see what that tells me, also forgot to mention that the oil light only starts flashing at me when it is warm, when it's cold it's fine. Bryan Link to comment Share on other sites More sharing options...
ScORTED Posted February 4, 2010 Share Posted February 4, 2010 probably a knackered engine then as above test the oil pressure, are you using the correct grade? Link to comment Share on other sites More sharing options...
Brylt Posted February 4, 2010 Author Share Posted February 4, 2010 probably a knackered engine then as above test the oil pressure, are you using the correct grade? I was thinking of buying some supermarket cheepo flushing oil just to tip through it and see what happens. Bryan Link to comment Share on other sites More sharing options...
stevmo3691 Posted February 6, 2010 Share Posted February 6, 2010 tbh a 276K 1.6 zetec has had a long hard life. they tend to be good to 150-180K (average) obviously a perfectly maintained one will do more but chances are you've already done the damage by now. normally by the time you get the warning light its to late so best bet is either new engine, or atleast top end. Link to comment Share on other sites More sharing options...
rodney,. Posted February 7, 2010 Share Posted February 7, 2010 sounds like a dead oil pump , ive done a couple now, tbh if its rattling then replace it , go 18 or 2.0 for the sme money as gettin a new oil pump fitted,. Link to comment Share on other sites More sharing options...
Brylt Posted February 8, 2010 Author Share Posted February 8, 2010 Well the engine bit the dust this afternoon, so it looks like i'll be dropping engine a box out of my breaker tomorow.It was seeming to be better so that must have been the preverbial light bulb Bryan Link to comment Share on other sites More sharing options...
