Rosco Posted February 1, 2010 Share Posted February 1, 2010 hi guys, did a quick search on this but decided to put my own post up to see if anyone can provide any pointers. I'm running a healthy 2.0 zetec with 130 spec inlet, throttle body, ecu etc and a standard XR3i exhaust manifold and system. However the fuel consumption is pretty bad, even when just cruising about. Its in a stripped out mk4 escort so not really a heavy car to pull about. Engine has just had a fresh oil change also. I'm thinking of replacing the lambda sensor, and maybe plugs etc. Car runs perfect and goes like the clappers when you want it too, just i expected a little bit better economy, at the moment i'm getting about 40 miles to a tenner? CheeRS Link to comment Share on other sites More sharing options...
Stu Posted February 1, 2010 Share Posted February 1, 2010 You can't use money in a fuel consumption discussion as fuel prices change. Can you clarify your statement by saying how many miles you get to a litre/gallon? Detail exact what injectors, MAF, ECU you're running. Link to comment Share on other sites More sharing options...
SteveB Posted February 1, 2010 Share Posted February 1, 2010 To get an accurate figure of mileage you need to fill the tank all the way - reset the trip recorder - run it around until you're down to half a tank or so - fill it all the way again and note how many litres you put in and what the trip recorder says. Link to comment Share on other sites More sharing options...
Trig Posted February 1, 2010 Share Posted February 1, 2010 I put £55 of diesel in mine yesterday and will get 510 miles out of it, 2 weeks ago I put in £56 of diesel and got 490 miles. The difference has something to do with only paying £1.109 yesterday and £1.149 a couple of weeks ago, Link to comment Share on other sites More sharing options...
Rosco Posted February 1, 2010 Author Share Posted February 1, 2010 in terms of injectors etc, its just standard as removed from the mk5 XR3i but bolted on to a silver top 2.0. not really had car on road long so will try gettin a decent mpg reading if it doesnt bankrupt me first! Link to comment Share on other sites More sharing options...
Stu Posted February 1, 2010 Share Posted February 1, 2010 If you're not running the proper ecu/maf/injectors for the 2L engine then don't expect miracles. Link to comment Share on other sites More sharing options...
Rosco Posted February 2, 2010 Author Share Posted February 2, 2010 If you're not running the proper ecu/maf/injectors for the 2L engine then don't expect miracles. Not expecting miracles, just didnt expect it to be so thirsty. Link to comment Share on other sites More sharing options...
Stu Posted February 2, 2010 Share Posted February 2, 2010 If you're not running the proper ecu/maf/injectors for the 2L engine then don't expect miracles. Not expecting miracles, just didnt expect it to be so thirsty. Well at least now you know what the effect is of running the wrong stuff. Link to comment Share on other sites More sharing options...
Rosco Posted February 2, 2010 Author Share Posted February 2, 2010 seen a few cars run this set up and i dont imagine they would put up with this economy - its not as if the car runs erratically or anything, it runs absolutely perfect. Just didnt think it'd use more fuel than my Cossie! Link to comment Share on other sites More sharing options...
