senglea Posted February 1, 2010 Share Posted February 1, 2010 hi guys,how in gods name do you remove clutch cable/disconnected it from paw ratchet and from front end but cable will only come out about six inches,any advice would be greatly received.cheers Link to comment Share on other sites More sharing options...
The Badger Posted February 4, 2010 Share Posted February 4, 2010 You need to start at the gearbox end, with pliers you need to disengage the cable from the release lever/arm, don't damage the cable if it is to be re-used, then take the cable out of the locating lug. Once this is done you need to go into the footwell, you should see a spring going from the pedal to the bulk head/pedal box, take this spring off and then you should just be able to remove the cable from the quadrant. Then it should just be a matter of withdrawing the cable through the bulk head and into the engine bay. Hope this helps Regards James Link to comment Share on other sites More sharing options...
