kris Posted February 3, 2010 Share Posted February 3, 2010 wouldit be possable to fit a st170 gearbox onto a silvertop zetec and if so what parts would be needed? also is it worth doing? an is there any benefits apart form the extra gear? kris Link to comment Share on other sites More sharing options...
sidrick Posted February 3, 2010 Share Posted February 3, 2010 Probably worth using the search function for the 478563489567834629653456574565734534564657432356473574234365574436234545685435234465443653254154656345231455416473568443623655446583645364665836544366 topics on this Link to comment Share on other sites More sharing options...
SLEEMAN Posted February 3, 2010 Share Posted February 3, 2010 some say its pointless as the st170 gearbox has close ratio gears, probably worth investing in some longer ratio gears from quaife! Link to comment Share on other sites More sharing options...
Stu Posted February 4, 2010 Share Posted February 4, 2010 some say its pointless as the st170 gearbox has close ratio gears, probably worth investing in some longer ratio gears from quaife! Why are short ratios pointless? Link to comment Share on other sites More sharing options...
SLEEMAN Posted February 4, 2010 Share Posted February 4, 2010 do you want the engine screaming at 3-4000rpm doing 70-80 on the motorway? i'd rather not plus it would be ecomonic to have longer gear ratios saves on fuel! close ratio boxes i think are better for racing and rallying! Link to comment Share on other sites More sharing options...
Stu Posted February 4, 2010 Share Posted February 4, 2010 do you want the engine screaming at 3-4000rpm doing 70-80 on the motorway? i'd rather not plus it would be ecomonic to have longer gear ratios saves on fuel! close ratio boxes i think are better for racing and rallying! Er.. hello.. ST170 is 6 speed.. Link to comment Share on other sites More sharing options...
SLEEMAN Posted February 4, 2010 Share Posted February 4, 2010 i know its 6 speed! but i have read in fast ford a couple of times especially in recent issues that its pointless putting one in an escort unless it REALLY needs it like i dunno if you have 2-300bhp! plus the fact that theres custom mounts, welding etc put it this way putting an st170 box in would cost more than putting that turbo engine in your car kris if done by a pro. some people have done it in fiesta mk3's because its easy to do in them! i would go for a fully uprated ib5 box with LSD kris having 6 gears in an escort would be brilliant but for the cost of getting the parts and getting it fitted would just literally kill your wallet! Link to comment Share on other sites More sharing options...
dutchkev Posted February 4, 2010 Share Posted February 4, 2010 my 5 speed sits at 3k at 70mph Link to comment Share on other sites More sharing options...
bluliz Posted February 4, 2010 Share Posted February 4, 2010 my 5 speed sits at 3k at 70mph 6th gear @3k rpm = circa 70mph. From my experience of owning an escort 1.8 at the same time as an ST170, 2nd gear has a very similar ratio to the 2nd in the 5speed box, both about 10mph per 1k rpm. 3rd is shorter as is 4th. Link to comment Share on other sites More sharing options...
stoney Posted February 4, 2010 Share Posted February 4, 2010 wouldit be possable to fit a st170 gearbox onto a silvertop zetec and if so what parts would be needed? also is it worth doing? an is there any benefits apart form the extra gear? kris any way going back to the original question. gearbox gearlinkage pedal box as i beleive that these are hydraulic cutches ( could be wrong tho) drive shafts possibly hubs and no not worth the ball ache tbh mate Link to comment Share on other sites More sharing options...
stoo2000 Posted February 4, 2010 Share Posted February 4, 2010 wouldit be possable to fit a st170 gearbox onto a silvertop zetec and if so what parts would be needed? also is it worth doing? an is there any benefits apart form the extra gear? kris any way going back to the original question. gearbox gearlinkage pedal box as i beleive that these are hydraulic cutches ( could be wrong tho) drive shafts possibly hubs and no not worth the ball ache tbh mate It does use a hydraulic clutch, I'm sure it uses a cable for the gear selector too. Not 100% sure on that though. SortedFord has a clean St170 box he may sell... Link to comment Share on other sites More sharing options...
tezmanian devil Posted February 4, 2010 Share Posted February 4, 2010 get a mtx75, all bolt on, cheaper, stronger and easier to fit Link to comment Share on other sites More sharing options...
Hezz Posted February 4, 2010 Share Posted February 4, 2010 do you want the engine screaming at 3-4000rpm doing 70-80 on the motorway? most cars do them sort of rpms at those speeds hardly redlining is it! Link to comment Share on other sites More sharing options...
SLEEMAN Posted February 4, 2010 Share Posted February 4, 2010 but not good on fuel though! if i could i would make sure the car revs around 2k at 75 or 80 so therefore within legal limit and saving on fuel! Link to comment Share on other sites More sharing options...
Stu Posted February 5, 2010 Share Posted February 5, 2010 get a mtx75, all bolt on, cheaper, stronger and easier to fit It's not stronger. Link to comment Share on other sites More sharing options...
