benrs Posted February 3, 2010 Share Posted February 3, 2010 Hey. Can anybody tell me where the gear box oil filling plug is on 1.6 16v zetec? Many Thanks Link to comment Share on other sites More sharing options...
shawdreamer Posted February 3, 2010 Share Posted February 3, 2010 Hey. Can anybody tell me where the gear box oil filling plug is on 1.6 16v zetec? Many Thanks side of the gearbox closest to the front of the car.... about an inch up from the gearbox base you'll find a 1/2 grub bolt which needs a 8mm allan key to remove. car must be level when filling (cannot be partially lifted on a jack or stands) as there is no fill indicator, instead the ideal oil level to fill to is when the oil begins to trickle back out the oil fill hole. Link to comment Share on other sites More sharing options...
ScORTED Posted February 4, 2010 Share Posted February 4, 2010 you can fill it through the plastic plug on the top but you need the car level and the upper plug on the side at the front (level plug) open to check oyu have the right amount in, the lower plug is for draining. Link to comment Share on other sites More sharing options...
