bongo Posted February 4, 2010 Share Posted February 4, 2010 as my engine is currently using a good amount of oil,i ve been told bey a local mechanic that my rings are worn,so i'm definately looking into a new engine which i would like to strip and rebuild,so what would be a basic rebuild? what gaskets etc.cleaning etc.and what would i replace. i dont want to spend loads just perform a basic rebuild to return the engine to most of its former glory. thanks marc. Link to comment Share on other sites More sharing options...
Stu Posted February 5, 2010 Share Posted February 5, 2010 The first thing to do is strip the engine and measure the piston to bore clearance. If it's outside spec then it's not worth rebuilding. Link to comment Share on other sites More sharing options...
bongo Posted February 5, 2010 Author Share Posted February 5, 2010 (edited) The first thing to do is strip the engine and measure the piston to bore clearance. If it's outside spec then it's not worth rebuilding. what would i need to do this? but could you tell me what you would renew or replace, as i can start buying and searching for parts Edited February 5, 2010 by bongo Link to comment Share on other sites More sharing options...
Stu Posted February 5, 2010 Share Posted February 5, 2010 Building engines isn't simply about fitting parts, it's about cleaning, measuring, more cleaning and double checking on your measuring, then making appropriate decisions. And it's highly unlikely to be worn rings on your engine. I've taken about zetec engines with over 100k on them with very worn bores, but the rings are practically un-worn. Link to comment Share on other sites More sharing options...
bongo Posted February 5, 2010 Author Share Posted February 5, 2010 all i know is that it just passed the emissions after a few attemts,i use 2 litres of oil a month,and when checking the plugs no 1 and 2 plugs are caked in a white brownish deposit. Link to comment Share on other sites More sharing options...
Stu Posted February 5, 2010 Share Posted February 5, 2010 Worn valve guides are common on zetecs.. did your expert mechanic do a leak down test to help his diagnosis? Link to comment Share on other sites More sharing options...
bongo Posted February 5, 2010 Author Share Posted February 5, 2010 no stu,just told him what i knew and thats what he said,so worn valve guides would cause all of the above even to the extent of 2 litres of oil a month? Link to comment Share on other sites More sharing options...
Stu Posted February 5, 2010 Share Posted February 5, 2010 no stu,just told him what i knew and thats what he said,so worn valve guides would cause all of the above even to the extent of 2 litres of oil a month? Possibly. It also depends on how many miles you're doing in that month! Either way, if you're not going to get your head reconditioned during the engine rebuild you may not fixing your issue and throwing money down the toilet. If you want to know how to do it properly, I recommend this book: http://ecx.images-amazon.com/images/I/51KWrqQfFyL._BO2,204,203,200_PIsitb-sticker-arrow-click,TopRight,35,-76_AA240_SH20_OU02_.jpg It gives you lots of best practises to think about. It's not mainly about DOHC engines though, but will give you some good insight into what's required to do a proper job. Link to comment Share on other sites More sharing options...
bongo Posted February 5, 2010 Author Share Posted February 5, 2010 thanks Link to comment Share on other sites More sharing options...
