shaung Posted February 6, 2010 Share Posted February 6, 2010 hi guys i just been out in my escort turbo and when i rev it theres a funny noise comein from the air filter does any 1 no what it could be cheers shaun.its like a loude wistle type noise. Link to comment Share on other sites More sharing options...
stoney Posted February 6, 2010 Share Posted February 6, 2010 air leak? can u be abit more specific pls matey Link to comment Share on other sites More sharing options...
shaung Posted February 6, 2010 Author Share Posted February 6, 2010 air leak? can u be abit more specific pls mateyive got an escort with a zetec turbo fitted but the air filter comes off the turbo and every time i rev the engain theres a wired noise comein though the air filter which ive never heard b4 i cant realy explain the the noise its weired lol and its startin to do my head in lol. Link to comment Share on other sites More sharing options...
shawdreamer Posted February 6, 2010 Share Posted February 6, 2010 air leak? can u be abit more specific pls mateyive got an escort with a zetec turbo fitted but the air filter comes off the turbo and every time i rev the engain theres a wired noise comein though the air filter which ive never heard b4 i cant realy explain the the noise its weired lol and its startin to do my head in lol. "weird noise" isnt exactly very simple to diagnose, you'll need to be alot more specific! for starters.... can you narrow the location down a bit more?is it coming from the turbo itselfis it coming from the air intakeis it coming from the crank caseis it coming from the crossover the noise, is it .... a whine (metalic type)a squeel (like a belt slip)a whistle (as in air whistle) are there any other symptoms?...a loss of powera missfireincreased oil usageincreased fuel usageloss of boostlumpy engine and anything else that might spring to mind Link to comment Share on other sites More sharing options...
shaung Posted February 6, 2010 Author Share Posted February 6, 2010 air leak? can u be abit more specific pls mateyive got an escort with a zetec turbo fitted but the air filter comes off the turbo and every time i rev the engain theres a wired noise comein though the air filter which ive never heard b4 i cant realy explain the the noise its weired lol and its startin to do my head in lol. "weird noise" isnt exactly very simple to diagnose, you'll need to be alot more specific! for starters.... can you narrow the location down a bit more?is it coming from the turbo itselfis it coming from the air intakeis it coming from the crank caseis it coming from the crossover the noise, is it .... a whine (metalic type)a squeel (like a belt slip)a whistle (as in air whistle) are there any other symptoms?...a loss of powera missfireincreased oil usageincreased fuel usageloss of boostlumpy engine and anything else that might spring to mindits cumin from the air intake and its like a whistlein noise air leak? can u be abit more specific pls mateyive got an escort with a zetec turbo fitted but the air filter comes off the turbo and every time i rev the engain theres a wired noise comein though the air filter which ive never heard b4 i cant realy explain the the noise its weired lol and its startin to do my head in lol. "weird noise" isnt exactly very simple to diagnose, you'll need to be alot more specific! for starters.... can you narrow the location down a bit more?is it coming from the turbo itselfis it coming from the air intakeis it coming from the crank caseis it coming from the crossover the noise, is it .... a whine (metalic type)a squeel (like a belt slip)a whistle (as in air whistle) are there any other symptoms?...a loss of powera missfireincreased oil usageincreased fuel usageloss of boostlumpy engine and anything else that might spring to mindits cumin from the air intake and its like a whistlein noise also the car will cut out every now and again but starts straights back up. Link to comment Share on other sites More sharing options...
scottg17 Posted February 6, 2010 Share Posted February 6, 2010 turbos usually do whistle Link to comment Share on other sites More sharing options...
shaung Posted February 6, 2010 Author Share Posted February 6, 2010 turbos usually do whistle no the noise comes after the turbo as spooled up when its just tickin over after youve reved it. Link to comment Share on other sites More sharing options...
rodney,. Posted February 7, 2010 Share Posted February 7, 2010 as the engine drops back to idle? , only thing it could really be if not the turbo whistling on spin up then id say its just the turbo slowing down again , could have noisy bearings , id say undo the air filter pipe where it goes into turbo and check for up and down and in and out play in the turbos shaft,. Link to comment Share on other sites More sharing options...
shaung Posted February 7, 2010 Author Share Posted February 7, 2010 as the engine drops back to idle? , only thing it could really be if not the turbo whistling on spin up then id say its just the turbo slowing down again , could have noisy bearings , id say undo the air filter pipe where it goes into turbo and check for up and down and in and out play in the turbos shaft,.yeah will do does that mean the turbos fooked lol cos theres no smoke etc Link to comment Share on other sites More sharing options...
rodney,. Posted February 7, 2010 Share Posted February 7, 2010 yeah the bearing will have gone mate , what also happens when this goes is the propelor blades can hit the housing on spin up or down , if it is then im sure one ov the boys over on www.xrtwo.com or www.shitboxracing.co.uk , theres a few boys on there that break and run xr2's with escort turbo lumps,. Link to comment Share on other sites More sharing options...
shaung Posted February 7, 2010 Author Share Posted February 7, 2010 yeah the bearing will have gone mate , what also happens when this goes is the propelor blades can hit the housing on spin up or down , if it is then im sure one ov the boys over on www.xrtwo.com or www.shitboxracing.co.uk , theres a few boys on there that break and run xr2's with escort turbo lumps,.ok will look 2moz if its not that what else do ya think it could be lol Link to comment Share on other sites More sharing options...
rodney,. Posted February 7, 2010 Share Posted February 7, 2010 goin by what you have told us there cant be anything else really without looking at it,. Link to comment Share on other sites More sharing options...
shaung Posted February 7, 2010 Author Share Posted February 7, 2010 goin by what you have told us there cant be anything else really without looking at it,.ok mate cheers for ya help just hope the turbos fine lol Link to comment Share on other sites More sharing options...
