daddycool Posted February 7, 2010 Share Posted February 7, 2010 Hi guys im new here and hope u can help me out,I just brought a escort si 1.8 convertible (yellow) 1995. Very clean car indeed.Well it dont seem to have much pulling power for a 130bhp car, ticks over nicely and its not very noisey at all, has 92k on clock.When car is warm it seems to run pants, not power at all.When i Accelerate the car like judders then goes and by saying goes it slow increases speed, also tends to wana go to the left when Accelerated but tracking seems ok when not Accelerateing.The temp gauge isnt working properly it dnt seem to be overheating. Also pedals for clutch and brake seem creeky and brakes aint to good. any help will be most thank full. its only a day old and cost me £1000,has 11 months mot and some tax. so dnt no a great deal but its only had like 3 long owners, and reg serviced. Link to comment Share on other sites More sharing options...
dutchkev Posted February 7, 2010 Share Posted February 7, 2010 firstly welcome to EVO secondly, check the plugs and the CAT, the plugs could be fecked or the cat could be blocked thirdly, the temp gauge could be the temp sender fourthly, check the brake pads/disks. the creaking could be the bar they sit on, might need a greasing lastly the pulling could be either traking/lower arms or track rod ends Link to comment Share on other sites More sharing options...
daddycool Posted February 7, 2010 Author Share Posted February 7, 2010 nice 1 dutch kev,was thinking of the thermastat? if thats sticking when car is hot it would make my car run like crap?just feels so low on power and no guts at all as i had same engine years bk. Link to comment Share on other sites More sharing options...
dutchkev Posted February 8, 2010 Share Posted February 8, 2010 it would run hot, but unlikely like crap, although it wont help. check the other things over first and see how that goes Link to comment Share on other sites More sharing options...
daddycool Posted February 8, 2010 Author Share Posted February 8, 2010 I checked the brakes and pads they look ok, brakes feel spongy checked the spark plugs and they are not gappt very good at all but what concerned me was the oil arounf the thread of the plugs, the end seem dry but rest of plug was coved in oil.is this a problem?, howi check if lower arms or track rod ends are naff? thank you Link to comment Share on other sites More sharing options...
daddycool Posted February 9, 2010 Author Share Posted February 9, 2010 Can any1 help me?, just needa bit of info about the spark plugs,i removed them and they all have oil around them but dnt seem to have oil on the tip but te threads were dripping Link to comment Share on other sites More sharing options...
dutchkev Posted February 9, 2010 Share Posted February 9, 2010 i had the same problem - i needed a new rocker gasket. and you have the same problem, the gasket between the rocker cover and the head has eroded and oil is leaking into the plugs. i would suggest a new gasket, new plugs and new HT leads regards the lower arms, have a look undernear at them. or take them to a tyre place, they can look over them for you there Link to comment Share on other sites More sharing options...
kevscort15 Posted February 9, 2010 Share Posted February 9, 2010 yeh common problem on the escort the cat collapsing ,removed my cat today what a different motor ,power delivery is a lot better, dont seem to be holding back now Link to comment Share on other sites More sharing options...
daddycool Posted February 9, 2010 Author Share Posted February 9, 2010 U removed cat? u have no cat on your car?my car has MOT till nov so can a cat be a prob, i had the same problem - i needed a new rocker gasket. and you have the same problem, the gasket between the rocker cover and the head has eroded and oil is leaking into the plugs. i would suggest a new gasket, new plugs and new HT leads regards the lower arms, have a look undernear at them. or take them to a tyre place, they can look over them for you there so would that make a problem to my car performance?it seems to take bit longer to start when hot too. is it easy to change rocker gasket?are they torque screws on the rocker? thanks Link to comment Share on other sites More sharing options...
kevscort15 Posted February 9, 2010 Share Posted February 9, 2010 Yeh can be if its faulty ,mot aint a prob it aint what u no but who you no Yeh can be if its faulty ,mot aint a prob it aint what u no but who you no Link to comment Share on other sites More sharing options...
daddycool Posted February 10, 2010 Author Share Posted February 10, 2010 was told today by ford it maybe the engine temp managment sensor or coolent temp sensor as it does have much power when engine hot. Wish i new what these do as i dnt wana buy somet i dnt need Link to comment Share on other sites More sharing options...
daddycool Posted February 10, 2010 Author Share Posted February 10, 2010 changed the plugs today and still the same, old 1's where white at end with bit of oil around the thread. My probel still continues,my car seems good on fuel but very flat when accelerating and even sounds flat.I read up on a forum that a maf sensor can be the prob as its taking abit to start at times.Forum said if u dissconnect maf sensor and engine is still reving the same then its a faulty maf.well i unplugged it and my car ticks over and revs the same as it does with or without.is this my problem lads? An engine with a bad MAF sensor may start and stall or be hard to start, it may hesitate under load, idle rough or run excessively rich or lean. The engine may also hiccup when the throttle suddenly changes position. thats from a site,mine starting to take bit of time to start, think its lean as i did 215miles for £20, and hesitates on accelaration this is expensive however any1 no if this will fit mine? mines a 1.8 thohttp://cgi.ebay.co.uk/Mass-Air-Flow-Meter-...=item3ca9e0d0f7 Link to comment Share on other sites More sharing options...
dutchkev Posted February 10, 2010 Share Posted February 10, 2010 as long as the code matches up with yours then it'll fit - but it could well be a problem if it has no effect Link to comment Share on other sites More sharing options...
daddycool Posted February 10, 2010 Author Share Posted February 10, 2010 well the part i brought is: 92FB12B579BAand mine on the car is 92BB12B579BAAs u can see i have 92BB and part i brought is 92FB Was told the that the letter was ok as it has somet to do with the year of car.Hopefully that comes friday and i can try, u think i should just swap the sensor or swap the inlet bit as well as the part i brought comes with the inlet bit.£9.90 with delivery Bargain Link to comment Share on other sites More sharing options...
dutchkev Posted February 11, 2010 Share Posted February 11, 2010 if it in good conditon, swap the whole lot over Link to comment Share on other sites More sharing options...
