Oobyscoot Posted February 8, 2010 Share Posted February 8, 2010 Hi, Can any of you knowledgeable folk out there in escort evolution land tell me where to find the fuel cut of switch on my 1995 escort 1.4 encore ? Cheers, Link to comment Share on other sites More sharing options...
Stu Posted February 8, 2010 Share Posted February 8, 2010 They're usually in the drivers side passenger kick trim on zetec-engined cars, but not 100% sure it's in the same place for a CVH. Link to comment Share on other sites More sharing options...
Oobyscoot Posted February 8, 2010 Author Share Posted February 8, 2010 They're usually in the drivers side passenger kick trim on zetec-engined cars, but not 100% sure it's in the same place for a CVH. Cheers, Will have a look tonight. I had been told they were in the boot, but no sign of it there. Just out of interest, do you know if the CVH is an interference engine or not? Link to comment Share on other sites More sharing options...
Stu Posted February 8, 2010 Share Posted February 8, 2010 Yes it is.. Link to comment Share on other sites More sharing options...
Oobyscoot Posted February 8, 2010 Author Share Posted February 8, 2010 Yes it is.. Hmmm, may have to think about getting a timing belt for it then, Its done 75K. Is the zetec engine an interference engine do you know? The misses' focus is about due for a belt as well. Link to comment Share on other sites More sharing options...
Stu Posted February 8, 2010 Share Posted February 8, 2010 Yup.. Link to comment Share on other sites More sharing options...
Oobyscoot Posted February 9, 2010 Author Share Posted February 9, 2010 Yup.. Ok, Looked behind the passenger kick trim and all I could see was what looked like an ecu. No sign of a fuel cut off switch. Any other suggestions ? Link to comment Share on other sites More sharing options...
shawdreamer Posted February 9, 2010 Share Posted February 9, 2010 (edited) Ok, Looked behind the passenger kick trim and all I could see was what looked like an ecu. No sign of a fuel cut off switch. Any other suggestions ? They're usually in the DRIVERS side passenger kick trim on zetec-engined cars, but not 100% sure it's in the same place for a CVH. Edited February 9, 2010 by shawdreamer Link to comment Share on other sites More sharing options...
Oobyscoot Posted February 9, 2010 Author Share Posted February 9, 2010 (edited) Ok, Looked behind the passenger kick trim and all I could see was what looked like an ecu. No sign of a fuel cut off switch. Any other suggestions ? They're usually in the DRIVERS side passenger kick trim on zetec-engined cars, but not 100% sure it's in the same place for a CVH. D'OH!!!!!!!!!!!!Well that would explain why I didn't find it. Silly arse that I am. I will Have a look behind the DRIVERS side kick trim tonight and see if I see it there......... Thank you for pointing out my stupidity....... Must try harder............ Edited February 9, 2010 by Oobyscoot Link to comment Share on other sites More sharing options...
SteveB Posted February 9, 2010 Share Posted February 9, 2010 You should find a small cover plate on the kick trim - the cut off is behind this - if you have one that is. Link to comment Share on other sites More sharing options...
Oobyscoot Posted February 9, 2010 Author Share Posted February 9, 2010 You should find a small cover plate on the kick trim - the cut off is behind this - if you have one that is. I will look later this evening. I only ask because i put the sun visor down the other day and saw a big sticker telling me that the vehicle is fitted with a fuel cut-off switch and I should read the handbook for reset details. I dont have a handbook, so I would just like to know how to reset it just in case. There was a small cover on the passenger kick trim but that looked like the diagnostic plug. Maybe I will have more luck if I actually look in the right place. Link to comment Share on other sites More sharing options...
SteveB Posted February 9, 2010 Share Posted February 9, 2010 You should find a small cover plate on the kick trim - the cut off is behind this - if you have one that is. I will look later this evening. I only ask because i put the sun visor down the other day and saw a big sticker telling me that the vehicle is fitted with a fuel cut-off switch and I should read the handbook for reset details. I dont have a handbook, so I would just like to know how to reset it just in case. There was a small cover on the passenger kick trim but that looked like the diagnostic plug. Maybe I will have more luck if I actually look in the right place. The reset cover looks pretty much the same as the diagnostic cover - just in the other footwell. Link to comment Share on other sites More sharing options...
Oobyscoot Posted February 10, 2010 Author Share Posted February 10, 2010 Found it...... Only trouble is, now I have the airbag light flashing. I think I must have disturbed something behind there. Is there anything behind the kick trim that is to do with the SRS system. I have the airbag light giving 4 flashes then pause, then 4 flashes and so on......... Why didn't I just leave it well alone ? Link to comment Share on other sites More sharing options...
Stu Posted February 10, 2010 Share Posted February 10, 2010 I can't remember the flashing code for the airbag system, but you've got the selt belt tensions down near the seat which you may have dislodged.. otherwise just check behind the kick trim for any connectors.. although I think it's unlikely you've done anything behind there. Link to comment Share on other sites More sharing options...
Oobyscoot Posted February 10, 2010 Author Share Posted February 10, 2010 I can't remember the flashing code for the airbag system, but you've got the selt belt tensions down near the seat which you may have dislodged.. otherwise just check behind the kick trim for any connectors.. although I think it's unlikely you've done anything behind there. Ah, now I did move the drivers seat back then fully forward then back to where it began as I dropped me fag lighter and had trouble retrieving it, maybe I disturbed something doing that...... Link to comment Share on other sites More sharing options...
