rufio_gti Posted February 10, 2010 Share Posted February 10, 2010 I got the chance to get some brakes for my gti they are off a rs2000 will I have any problems with the abs? Link to comment Share on other sites More sharing options...
KNITERIDER Posted February 10, 2010 Share Posted February 10, 2010 nope, straight swap. pointless imo opinion tho as there is very little difference between them and standard brakes, personally id go the next size up (cossie discs and v6 callipers.) Link to comment Share on other sites More sharing options...
JC Posted February 10, 2010 Share Posted February 10, 2010 No problem in swapping the front off an RS2000, IMO worth the up grade from standard, and was told they are the largest setup to fit behind snadard 15" alloys Link to comment Share on other sites More sharing options...
rufio_gti Posted February 10, 2010 Author Share Posted February 10, 2010 Just that I've come to renewing them and they came up cheap. You have to drill holes for the v6 calipers Link to comment Share on other sites More sharing options...
ScORTED Posted February 10, 2010 Share Posted February 10, 2010 if you use cosworth calipers you don't have to drill the hubs out and cosworth calipers fit under 90% of 15" wheels Link to comment Share on other sites More sharing options...
rufio_gti Posted February 10, 2010 Author Share Posted February 10, 2010 Gti wheels? Is it the v6 claioers you have to drill the holes out 12mm? I think v6 are more sourcable than cossy ones? Link to comment Share on other sites More sharing options...
Hezz Posted February 10, 2010 Share Posted February 10, 2010 i'd upgrade to the rs2k ones you can always go up to st300mm or cossie 286mm ones later Link to comment Share on other sites More sharing options...
ScORTED Posted February 10, 2010 Share Posted February 10, 2010 the V6 and cosworth ones are the same calipers just the carriers are different as the mondeo has bigger lugs on the hub Link to comment Share on other sites More sharing options...
rufio_gti Posted February 10, 2010 Author Share Posted February 10, 2010 So I can use 300mm st disks with the rs2000 caliper Link to comment Share on other sites More sharing options...
JC Posted February 10, 2010 Share Posted February 10, 2010 So I can use 300mm st disks with the rs2000 caliper no. in a word. Link to comment Share on other sites More sharing options...
Hezz Posted February 10, 2010 Share Posted February 10, 2010 So I can use 300mm st disks with the rs2000 caliperno sorry mate - rs2k 260 disks with rs2k caliper- st170 300 disks with mondeo mk3 caliper- cossie 286 disks with cossie caliper Link to comment Share on other sites More sharing options...
rufio_gti Posted February 10, 2010 Author Share Posted February 10, 2010 Mint. Sod it rs2k it is Link to comment Share on other sites More sharing options...
