[ . D a r k // ] Posted February 19, 2010 Share Posted February 19, 2010 Right my engine is running like a bag of nails. It's running lumpy and struggling to rev over 2500-3000 rpm. It is a 1994 Zeta engine 1.8 [105ps] I've just changed the coil pack, Spark plugs and HT leads and it's not helped. Would a dodgy Lambada sensor or a failing cat converter cause running problems? Also had a new fusebox recently, could that be causing problems? Although it's been running fine for 2 weeks with the new fusebox in. I'm gonna take it for a compression test next week if I can't get it running properly again before hand, though it is NOT mixing oil and water (everything is fine on that front) Any suggestions or possible solutions would be much appreciated. Dark. Link to comment Share on other sites More sharing options...
dutchkev Posted February 19, 2010 Share Posted February 19, 2010 suspect the cat is shagged fella Link to comment Share on other sites More sharing options...
daddycool Posted February 19, 2010 Share Posted February 19, 2010 These engines have Crank sensors? am i have sim prob on few vauxhalls and was crank sensor Link to comment Share on other sites More sharing options...
corley Posted February 19, 2010 Share Posted February 19, 2010 i had a similar problem a while back, it was the cat as dutchkev suggested Link to comment Share on other sites More sharing options...
MikeyRS Posted February 21, 2010 Share Posted February 21, 2010 These engines have Crank sensors? am i have sim prob on few vauxhalls and was crank sensor crank sensor would create a non start problem, not running rough. check the breather hoses, 1 - top of the cam cover + 2 - front ov the engine and around under the coil pack if you here a rattling noise when reving then the cat will be fooked unplug the MAF meter and see if that makes any dif Link to comment Share on other sites More sharing options...
just kizi Posted February 21, 2010 Share Posted February 21, 2010 Right my engine is running like a bag of nails. It's running lumpy and struggling to rev over 2500-3000 rpm. It is a 1994 Zeta engine 1.8 [105ps] I've just changed the coil pack, Spark plugs and HT leads and it's not helped. Would a dodgy Lambada sensor or a failing cat converter cause running problems? Also had a new fusebox recently, could that be causing problems? Although it's been running fine for 2 weeks with the new fusebox in. I'm gonna take it for a compression test next week if I can't get it running properly again before hand, though it is NOT mixing oil and water (everything is fine on that front) Any suggestions or possible solutions would be much appreciated. Dark.sounds like the timing belt has lost tention or slipped a tooth it could be a burnt valve but it would need to be seveer and more than one to restrict the revs that much also have you checked the cam sensor if it has one hope this is of some use mate gary Link to comment Share on other sites More sharing options...
escrt1.4i Posted February 21, 2010 Share Posted February 21, 2010 mine is simalar and seems to be getting worse recently had a new cad made and fittted as mine didnt right when i fitted my 4 2 1 manifold but now its like im driving a kangaroo thats best way i can describe also has mo power Link to comment Share on other sites More sharing options...
[ . D a r k // ] Posted February 22, 2010 Author Share Posted February 22, 2010 Fixed it, The replacement set of HT leads was dodgy, Wasn't until after dark see them sparking. Exchanged them for another set and it's been running fine. Link to comment Share on other sites More sharing options...
