keith83 Posted February 20, 2010 Share Posted February 20, 2010 As title says i need to replace the rear brake shoes on a mk6 gti how easy is this to do and how much is it likely to cost? Link to comment Share on other sites More sharing options...
16Vrhys Posted February 20, 2010 Share Posted February 20, 2010 how easy - not to bad if you have done them before , first timers they are a bugger! even are a bugger if you done them before lol! is a doable job though remove the rear drum by removing the large hub nut take note of where all the springs etc go and keep in a safe place , remove using pliers , refit and use new springs if have new springs but dont have to but recommended Link to comment Share on other sites More sharing options...
keith83 Posted February 20, 2010 Author Share Posted February 20, 2010 how easy - not to bad if you have done them before , first timers they are a bugger! even are a bugger if you done them before lol! is a doable job though remove the rear drum by removing the large hub nut take note of where all the springs etc go and keep in a safe place , remove using pliers , refit and use new springs if have new springs but dont have to but recommended Never done them before should i get someone to doit that has done them any idea how much they cost Link to comment Share on other sites More sharing options...
16Vrhys Posted February 20, 2010 Share Posted February 20, 2010 not sure how they charge per the job or hour , i reckon you can do it though just look where every thing goes isnt a hard job just fiddly Link to comment Share on other sites More sharing options...
dedmed90 Posted February 20, 2010 Share Posted February 20, 2010 and only do one side at a time then if u cant remember where the springs go you can look at the other side to remind you. Link to comment Share on other sites More sharing options...
