escrt1.4i Posted February 21, 2010 Share Posted February 21, 2010 my gti has abs i am looking to keep abs if possible and put 300mm set up off on the front aswell as the back so how do i go about keeping the abs Link to comment Share on other sites More sharing options...
dan1.8si Posted February 21, 2010 Share Posted February 21, 2010 the abs works off a ring behind the disk so you can fit 300mm with no bother mate the abs will still work Link to comment Share on other sites More sharing options...
escrt1.4i Posted February 21, 2010 Author Share Posted February 21, 2010 the abs works off a ring behind the disk so you can fit 300mm with no bother mate the abs will still work how woulkd this work with the rears as at the moment i have drum do have a rs2000 rear beam but looking to swop rs brakes for some st ones Link to comment Share on other sites More sharing options...
dan1.8si Posted February 21, 2010 Share Posted February 21, 2010 i would keep the rear rs set up as most off the braking is done by the front anyway mate. Link to comment Share on other sites More sharing options...
escrt1.4i Posted February 21, 2010 Author Share Posted February 21, 2010 i would keep the rear rs set up as most off the braking is done by the front anyway mate. but how will it work with rs set up as does not have abs ? Link to comment Share on other sites More sharing options...
RO55 Posted February 21, 2010 Share Posted February 21, 2010 i would keep the rear rs set up as most off the braking is done by the front anyway mate. but how will it work with rs set up as does not have abs ? Need to have Focus rear hubs machined for the Escort ABS Collector ring. .. The Escort Passive ABS is no compatable with the focus set up. Link to comment Share on other sites More sharing options...
dan1.8si Posted February 21, 2010 Share Posted February 21, 2010 some late mk6 rs200 with rear disks had abs, most were drums but have seen a fue with abs and disks. Link to comment Share on other sites More sharing options...
projectrs2k Posted February 21, 2010 Share Posted February 21, 2010 i would keep the rear rs set up as most off the braking is done by the front anyway mate. but how will it work with rs set up as does not have abs ? Need to have Focus rear hubs machined for the Escort ABS Collector ring. .. The Escort Passive ABS is no compatable with the focus set up. also needto drill the hole for the sensor to 15mm as the focus sensor is smaller Link to comment Share on other sites More sharing options...
hicksy Posted February 21, 2010 Share Posted February 21, 2010 some late mk6 rs200 with rear disks had abs, most were drums but have seen a fue with abs and disks. The rs2ks with rear discs only had abs on the front wheels Link to comment Share on other sites More sharing options...
escrt1.4i Posted February 21, 2010 Author Share Posted February 21, 2010 right so what simple disc conversion can i do to keep the abs on the rear as i have the 30omm setup for the front just unsure on how the abs will still work Link to comment Share on other sites More sharing options...
Hezz Posted February 21, 2010 Share Posted February 21, 2010 right so what simple disc conversion can i do to keep the abs on the rear as i have the 30omm setup for the front just unsure on how the abs will still workfocus - 2.0 270mm, st170 280mm Link to comment Share on other sites More sharing options...
escrt1.4i Posted February 22, 2010 Author Share Posted February 22, 2010 ok but i already have a 300mm set up for the front Link to comment Share on other sites More sharing options...
RO55 Posted February 22, 2010 Share Posted February 22, 2010 (edited) right so what simple disc conversion can i do to keep the abs on the rear as i have the 30omm setup for the front just unsure on how the abs will still work The only two conversion that I know of are. 1' Focus 2.0 16 ~/~ ST170 ~/~ ST150 and FRS rear set up. 255mm for the 2.0 16v and ST150. http://i127.photobucket.com/albums/p124/rosspec/Focus%20ABS/SSL23179.jpg 2' Golf GTi rear conversion .. ??????????? Edited February 22, 2010 by RO55 Link to comment Share on other sites More sharing options...
Craig855S Posted February 22, 2010 Share Posted February 22, 2010 Bah,just bin the ABS Link to comment Share on other sites More sharing options...
escrt1.4i Posted February 24, 2010 Author Share Posted February 24, 2010 might just go for bigger front brakes to be honest as i have already do have 300mm setup so can i keep abs with them or not Link to comment Share on other sites More sharing options...
