RAMBIRKETT Posted February 21, 2010 Share Posted February 21, 2010 Hi folks, i have a 1.1 fiesta 1993 and it had an intermediate starting problem. The led light goes crazy and now it doesnt start The car has now been off the road The starter turns over and the plugs are sparking but the fuel pump is not switching on. I've tried to run a fused switch live the the fuel pump to give me fuel to the injector. The fuel gets through to the injector but the injector is not working. Can i bypass the external pats system to get the fuel switched on again? Many Thanks Russell Link to comment Share on other sites More sharing options...
rodney,. Posted February 22, 2010 Share Posted February 22, 2010 external pats is easy to bypass , i had to do this after i did a engine change , run a live to the live on the coil pack,. Link to comment Share on other sites More sharing options...
SteveB Posted February 22, 2010 Share Posted February 22, 2010 external pats is easy to bypass , i had to do this after i did a engine change , run a live to the live on the coil pack,. If you read the post you'll see he's got spark but not fuel. RAMBIRKETT: let the PATS light flash and after 30 seconds it will start to flash a fault code at you. Link to comment Share on other sites More sharing options...
RAMBIRKETT Posted February 22, 2010 Author Share Posted February 22, 2010 external pats is easy to bypass , i had to do this after i did a engine change , run a live to the live on the coil pack,. If you read the post you'll see he's got spark but not fuel. RAMBIRKETT: let the PATS light flash and after 30 seconds it will start to flash a fault code at you. Right okay, i used to have an old vauxhall that you could count the flashes etc. Do you know where i can get a list of codes from? Thanks Link to comment Share on other sites More sharing options...
SteveB Posted February 22, 2010 Share Posted February 22, 2010 (edited) http://www.escortevolution.co.uk/forums/in...p;#entry1080513 Edited February 22, 2010 by SteveB Link to comment Share on other sites More sharing options...
rodney,. Posted February 22, 2010 Share Posted February 22, 2010 external pats is easy to bypass , i had to do this after i did a engine change , run a live to the live on the coil pack,. If you read the post you'll see he's got spark but not fuel. RAMBIRKETT: let the PATS light flash and after 30 seconds it will start to flash a fault code at you. youll also see that he asked if he can bypass the pats,. Link to comment Share on other sites More sharing options...
RAMBIRKETT Posted February 23, 2010 Author Share Posted February 23, 2010 external pats is easy to bypass , i had to do this after i did a engine change , run a live to the live on the coil pack,. If you read the post you'll see he's got spark but not fuel. RAMBIRKETT: let the PATS light flash and after 30 seconds it will start to flash a fault code at you. youll also see that he asked if he can bypass the pats,. The led flashes doesnt seam to flash a code after a certain amount of time. They just seam to flash rapidly until i switch the ignition off How can i bypass it to get the injector to fire? Many Thanks Russell Link to comment Share on other sites More sharing options...
RAMBIRKETT Posted February 24, 2010 Author Share Posted February 24, 2010 I'm still not making any progress with this Can someone PM or email me the details how to bypass the immobiliser? Thanks Russell Link to comment Share on other sites More sharing options...
RAMBIRKETT Posted February 25, 2010 Author Share Posted February 25, 2010 Can anyone help me out please ???? Link to comment Share on other sites More sharing options...
RAMBIRKETT Posted February 27, 2010 Author Share Posted February 27, 2010 My led is flashing code 15 (Incorrect key code, unprogrammed PATS key). I only have one key, so i cant try another one. Any ideas? Thanks Link to comment Share on other sites More sharing options...
16Vrhys Posted February 27, 2010 Share Posted February 27, 2010 wouldn't be a faulty key code reader around the ignition barrel would it ? worth a try being external pats u could replace the key and module aswell Link to comment Share on other sites More sharing options...
SteveB Posted February 28, 2010 Share Posted February 28, 2010 If you've damaged the key then you've either got to get an auto locksmith to sort it out for you, or do as 16Vrhys says and get a PATS modeule and keys. Link to comment Share on other sites More sharing options...
RAMBIRKETT Posted February 28, 2010 Author Share Posted February 28, 2010 If you've damaged the key then you've either got to get an auto locksmith to sort it out for you, or do as 16Vrhys says and get a PATS modeule and keys. Thanks, will give that a try Link to comment Share on other sites More sharing options...
RAMBIRKETT Posted March 2, 2010 Author Share Posted March 2, 2010 I've replaced the key and antenna ring this morning but guess what. Still flashing code 13 Grrrrrrrrrrr. Now i'm stuck! Any ideas? Thanks Link to comment Share on other sites More sharing options...
SteveB Posted March 2, 2010 Share Posted March 2, 2010 I've replaced the key and antenna ring this morning but guess what. Still flashing code 13 Grrrrrrrrrrr. Now i'm stuck! Any ideas? Thanks But last time you had 15 which was wrong key code - now you've got 13 which is cannot read key. Is the part number on the transceiver the same as the one you took off? Link to comment Share on other sites More sharing options...
