c.thomas Posted February 22, 2010 Share Posted February 22, 2010 am i good to go with the below oil http://www.opieoils.co.uk/p-60284-stock-re...edge-5w-30.aspx Link to comment Share on other sites More sharing options...
dutchkev Posted February 22, 2010 Share Posted February 22, 2010 are you doing a complete oil change? if so you'll need 5 litres of the stuff - so budget £50 for that lot but yes, 5w/30 is fine Link to comment Share on other sites More sharing options...
c.thomas Posted February 22, 2010 Author Share Posted February 22, 2010 are you doing a complete oil change? if so you'll need 5 litres of the stuff - so budget £50 for that lot but yes, 5w/30 is fine no just a top up kev Link to comment Share on other sites More sharing options...
dutchkev Posted February 22, 2010 Share Posted February 22, 2010 does it currently have 5w/30 in there? if so then your good to go Link to comment Share on other sites More sharing options...
c.thomas Posted February 22, 2010 Author Share Posted February 22, 2010 does it currently have 5w/30 in there? if so then your good to go thats the thing im not sure. Link to comment Share on other sites More sharing options...
dutchkev Posted February 22, 2010 Share Posted February 22, 2010 hmm, would be best to change it if your unsure - you can get 5 ltrs for £18 from asda Link to comment Share on other sites More sharing options...
c.thomas Posted February 22, 2010 Author Share Posted February 22, 2010 hmm, would be best to change it if your unsure - you can get 5 ltrs for £18 from asda would i not be better off getting the reputable oil? Link to comment Share on other sites More sharing options...
dutchkev Posted February 22, 2010 Share Posted February 22, 2010 well you could - but if the current oil is for example, cheap 10w/40 and the new oil is decent 5w/30, then if you add the good to the bad then it'll be a waste of time imo. if your changing the oil completely, get what you can afford, if you can get the castrol edge then go for it Link to comment Share on other sites More sharing options...
c.thomas Posted February 22, 2010 Author Share Posted February 22, 2010 well you could - but if the current oil is for example, cheap 10w/40 and the new oil is decent 5w/30, then if you add the good to the bad then it'll be a waste of time imo. if your changing the oil completely, get what you can afford, if you can get the castrol edge then go for it ok cheers mate Link to comment Share on other sites More sharing options...
