panda Posted February 23, 2010 Share Posted February 23, 2010 Changed my rear shoes as failed MOT on handbrake and now i cant get the drum back on to the drivers side. Anyone got any ideas? Also does anyone know how to adjust the handbrake as i cant see anyway of adjusting on cable. Cheers Panda Link to comment Share on other sites More sharing options...
projectrs2k Posted February 23, 2010 Share Posted February 23, 2010 to take carpet up you have to remove the bottom half of the back seat check underneath mate best way just a quick question your front carpet isnt wet aswell it? either you have adjusted your shoes out too far on that side or the drum has a serious lip (build up of rust)on the edge of the drum on the inside to adjust on cable lift the plastic trim and gaiter from arounf the handbrake lever and down the left hand side of the handbrake lever you will see a 10mm nut on a adjusting rod this is were you tension the handbrake up Link to comment Share on other sites More sharing options...
panda Posted February 24, 2010 Author Share Posted February 24, 2010 to take carpet up you have to remove the bottom half of the back seat check underneath mate best way just a quick question your front carpet isnt wet aswell it? either you have adjusted your shoes out too far on that side or the drum has a serious lip (build up of rust)on the edge of the drum on the inside to adjust on cable lift the plastic trim and gaiter from arounf the handbrake lever and down the left hand side of the handbrake lever you will see a 10mm nut on a adjusting rod this is were you tension the handbrake up Dont have a gaitor,its a mk5 with the plastic cubby thing for cassetes. Would i need to take this out to adjust ? Tryed Haynes book of lies but its no use. Link to comment Share on other sites More sharing options...
16Vrhys Posted March 8, 2010 Share Posted March 8, 2010 do it at the drums be best bet , just keep adjusting till slides on with a bit of resistance Link to comment Share on other sites More sharing options...
