deano1978 Posted February 27, 2010 Share Posted February 27, 2010 hi disconnected the battery yesterday to charge it for about 8 hours. now i have re connected the battery the car wont tick over. all the lights on the dash come on the headlights are working and the radio but when i turn the key to start the engine it is like i havent done anything the engine makes no sound at all. all the lights stay on and do not dim so i know its not the battery. how do i check to see if its the immobiliser? what else could it be? help please i am supposed to be selling it today. Link to comment Share on other sites More sharing options...
deano1978 Posted February 27, 2010 Author Share Posted February 27, 2010 hi disconnected the battery yesterday to charge it for about 8 hours. now i have re connected the battery the car wont tick over. all the lights on the dash come on the headlights are working and the radio but when i turn the key to start the engine it is like i havent done anything the engine makes no sound at all. all the lights stay on and do not dim so i know its not the battery. how do i check to see if its the immobiliser? what else could it be? help please i am supposed to be selling it today. it doesn't crank is what i mean the engine is completely dead please help! Link to comment Share on other sites More sharing options...
iks1966 Posted February 27, 2010 Share Posted February 27, 2010 had same sort of problem, it ended up being the fuse box under steering wheel, check the fuses first, if not change the fuse box, these are a common fault as water can track down the loom from the wing and it to the fuse box. Cheers Link to comment Share on other sites More sharing options...
demented Posted March 3, 2010 Share Posted March 3, 2010 Also ensure you have re- connected all the wires you took off the battery. I had a similar problem on a car once. I cant remember if it was a ford or not. I refitted the battery and re-connected everything, when I turned the ignition on, all the dash lights illuminated but there was no cranking. I had failed to notice one wire had slipped behind something in the engine bay. I think it was an Earth wire which went directly to the stater motor. Link to comment Share on other sites More sharing options...
rodney,. Posted March 4, 2010 Share Posted March 4, 2010 check the starter wire that comes thru ner the battery , its on a plug,. Link to comment Share on other sites More sharing options...
