Posted March 12, 201014 yr Hi folks I am thinking of getting myself a set of white digi dials but if I am going to do it, I want to change the fuel sender so it reads right. What is it that I need to remove and where is it? Also, does it just unplug then plug back in? Pictures would be helpful. Cheers Fraz
March 12, 201014 yr Hi folks I am thinking of getting myself a set of white digi dials but if I am going to do it, I want to change the fuel sender so it reads right. What is it that I need to remove and where is it? Also, does it just unplug then plug back in? Pictures would be helpful. Cheers Fraz YOU NEED TO DROP THE TANK AND REMOVE THE OLD SENDER AND PUT IN NEW SENDER.FAIRLY EASY JOB TO DO.I JUST HAPPEN TO HAVE WHITE DIGIS AND A SENDER FOR SALE Edited March 12, 201014 yr by mrmetallica
