Posted March 18, 201014 yr Hi , Ive now done my 2.0 swap into my previously 1.6 zetec and its running perfectly engine-wise but won't go into gear at all , A new clutch was put on too and since then the pedal is very close to the floor with only about 2.5" of pedal movement , any ideas what the dealio - I've come to a halt, Someone suggested it would be the gearlinkage but I very highly doubt that. Help appreciated
March 18, 201014 yr have you ajusted the clutch pedal using the ajuster at the top? might need winding out?
March 19, 201014 yr Didnt happen to be an LUK clutch by any chance? Same happened to mine rob, you getting a grinding noise at all?, clutch plate was shattered to ferk!
March 19, 201014 yr Author unlucky scott nah , its a borg&beck clutch , hopefully its the adjuster , ill have a look later.
March 19, 201014 yr unlucky scott nah , its a borg&beck clutch , hopefully its the adjuster , ill have a look later. should be okay then
March 19, 201014 yr the remote selector might just want adjusting if its not in the right position it wont select the gears or you will only get certain ones
