jd-gti Posted April 8, 2010 Share Posted April 8, 2010 Im wanting some info on how to go about changein the coulor of the hoese in the engine also what one yo do and not to do. What type of paint to use do i need to use primer on them. does it need to be heat paint ?? i work in a motor factors so paint is easy to come across Link to comment Share on other sites More sharing options...
shawdreamer Posted April 8, 2010 Share Posted April 8, 2010 Im wanting some info on how to go about changein the coulor of the hoese in the engine also what one yo do and not to do. What type of paint to use do i need to use primer on them. does it need to be heat paint ?? i work in a motor factors so paint is easy to come across Plastidip products are my recomendation. I tested there use on my previous Si using there latex based rubber paint and found it more than capable of coping with the heat,grime and flexing that go's on under the bonnet during daily use. multiple colours available (tho Id avoid the spraying versions as its too thin) and you can easily apply it all with a small fine brush without having stroke marks when your done Link to comment Share on other sites More sharing options...
