danny1987 Posted April 10, 2010 Share Posted April 10, 2010 (edited) as said, cheers i cant seem to get at the bolts behind the rad. whats my best way? Edited April 10, 2010 by danny1987 Link to comment Share on other sites More sharing options...
fluff2007 Posted April 10, 2010 Share Posted April 10, 2010 Small ratchet with a 13mm i believe! thats how i do mine! Link to comment Share on other sites More sharing options...
c.thomas Posted April 10, 2010 Share Posted April 10, 2010 (edited) as said, cheers undo the 2 nuts in each arch. and the 4 on the cross member. 2 each sidei believe their 13mm iirc<img src='http://www.evo-host.co.uk/getimg/23871.jpg' alt='Hosted at Evo-Host.co.uk'> Edited April 10, 2010 by c.thomas Link to comment Share on other sites More sharing options...
ScORTED Posted April 10, 2010 Share Posted April 10, 2010 13mm ratchet spanner from underneath, or if you've not / don't want to remove the undertrays take the grille off and use the mechanics bend to get your arm in Link to comment Share on other sites More sharing options...
danny1987 Posted April 10, 2010 Author Share Posted April 10, 2010 13mm ratchet spanner from underneath, or if you've not / don't want to remove the undertrays take the grille off and use the mechanics bend to get your arm in i have a 13m socket on my ratchet but i just get get a good enough grip on it, must be a easy way to access it, whole point of this anyway, i smashed my light and i cant get it out without taking off my bumper, now someone will tell me i can get the light out without taking it off lol. Link to comment Share on other sites More sharing options...
ScORTED Posted April 10, 2010 Share Posted April 10, 2010 no you can't theres a bolt underneat the light behind the bumper, just use a normal 13mm spanner but be prepared to be there awhile Link to comment Share on other sites More sharing options...
JC Posted April 10, 2010 Share Posted April 10, 2010 13mm ratchet spanner from underneath, or if you've not / don't want to remove the undertrays take the grille off and use the mechanics bend to get your arm in i have a 13m socket on my ratchet but i just get get a good enough grip on it, must be a easy way to access it, whole point of this anyway, i smashed my light and i cant get it out without taking off my bumper, now someone will tell me i can get the light out without taking it off lol. best to buy a 13mm ratchet spanner, makes the job much easier! Link to comment Share on other sites More sharing options...
caled Posted April 10, 2010 Share Posted April 10, 2010 I found it worked easily enough with a mini socket wrench and a 13mm socket. Do you have aircon? Link to comment Share on other sites More sharing options...
danny1987 Posted April 10, 2010 Author Share Posted April 10, 2010 I found it worked easily enough with a mini socket wrench and a 13mm socket. Do you have aircon? no, but i have with a great arse hole of a struggle get all bolts out (or so i thought) all bolts i can see are out eg. 1 either side of rad, 2 either arch, and it still wont ocm eout, its like the foamy rubbish is holding it on. what now? hope it doesnt get dark very quick Link to comment Share on other sites More sharing options...
PeeWee Posted April 10, 2010 Share Posted April 10, 2010 I found it worked easily enough with a mini socket wrench and a 13mm socket. Do you have aircon? no, but i have with a great arse hole of a struggle get all bolts out (or so i thought) all bolts i can see are out eg. 1 either side of rad, 2 either arch, and it still wont ocm eout, its like the foamy rubbish is holding it on. what now? hope it doesnt get dark very quick Firstly I hope you mean nuts NOT bolts.Secondly There are four nuts not two. Two nuts either side & two screws either side of the arches.As above, you really need a wratchet spanner 13mm to make light work of it. Link to comment Share on other sites More sharing options...
caled Posted April 10, 2010 Share Posted April 10, 2010 Here you go, this might make it a bit clearer for you. There are four nuts on the front cross member, two on each side, and I've highlighted them with the red arrows (well, the holes where the bolts would go)http://www.evo-host.co.uk/getimg/23872.jpg Incidentally, for those people with fogless bumpers, the blue connectors (circled) are for the front foglights if you want to upgrade to a fogged bumper. These are usually taped up under the arches and can be found easily when the bumper is off. Link to comment Share on other sites More sharing options...
danny1987 Posted April 11, 2010 Author Share Posted April 11, 2010 Here you go, this might make it a bit clearer for you. There are four nuts on the front cross member, two on each side, and I've highlighted them with the red arrows (well, the holes where the bolts would go)http://www.evo-host.co.uk/getimg/23872.jpg Incidentally, for those people with fogless bumpers, the blue connectors (circled) are for the front foglights if you want to upgrade to a fogged bumper. These are usually taped up under the arches and can be found easily when the bumper is off. thanks for this.... really helped alot, i did manage to get it finished! Link to comment Share on other sites More sharing options...
devman Posted April 12, 2010 Share Posted April 12, 2010 Here you go, this might make it a bit clearer for you. There are four nuts on the front cross member, two on each side, and I've highlighted them with the red arrows (well, the holes where the bolts would go)http://www.evo-host.co.uk/getimg/23872.jpg Incidentally, for those people with fogless bumpers, the blue connectors (circled) are for the front foglights if you want to upgrade to a fogged bumper. These are usually taped up under the arches and can be found easily when the bumper is off. Did you take your bumper off especially for this thread caled? Link to comment Share on other sites More sharing options...
caled Posted April 12, 2010 Share Posted April 12, 2010 haha, no, this was a while ago when I was putting the angel eyes in the 'scort. Link to comment Share on other sites More sharing options...
devman Posted April 12, 2010 Share Posted April 12, 2010 Yeah thats one of the many jobs i'm supposed to be doing this Saturday. Gonna be fun. Link to comment Share on other sites More sharing options...
