Posted April 18, 201014 yr alrite picked up a gti and the clutch is abit high,does this just need adjusting? plus om my way home found my self doing a few u-turns due to motorway closure and it seems when turning full lock i get a noise coming from passenger side,is this a cv joint issue? thanks michael
April 18, 201014 yr Ive always been under the assumption of the clutch self adjusting? there is a ratchet on the pedal. As for the noise, is the car lowered at all?
April 18, 201014 yr you can adjust the clutch pedal with a 6/7mm (cant mind which) allen key at the top of the pedal. what type of noise is it: scraping/clunking/sqealing? possible wheel rubbing or cv joint depending on which.
April 18, 201014 yr Author just a clunking mate,not really bad but want to keep on top of it really thanks pal
April 19, 201014 yr just a clunking mate,not really bad but want to keep on top of it really thanks pal repetative clunking during the turn or random clunking? repetative = cv joint, bearings random = cv, lower arm, arb bushes
April 19, 201014 yr Author tobehonest it ant really bad but tonight ive noticed it happens when gentle going up a curb and aso when i went up a hill and there was drop as u went over u here a clunk?that any help? michael
April 19, 201014 yr tobehonest it ant really bad but tonight ive noticed it happens when gentle going up a curb and aso when i went up a hill and there was drop as u went over u here a clunk?that any help? michael arbs are likely cause, wether arb links or bushes both relatively cheap to buy with the later being the more difficult to diy fit. less likely is lower arms which are also relatively cheap to replace and buy.
April 20, 201014 yr Author tobehonest it ant really bad but tonight ive noticed it happens when gentle going up a curb and aso when i went up a hill and there was drop as u went over u here a clunk?that any help? michael arbs are likely cause, wether arb links or bushes both relatively cheap to buy with the later being the more difficult to diy fit. less likely is lower arms which are also relatively cheap to replace and buy. thanks pal i think it is as it happens when i go over speed humps so i think its arb links? thanks for your help
