Posted April 25, 201014 yr underneath there is a gard ive took two 10mm bolts out , looks to be clips which just pulls out , and a few torx ? once these are removed i take it it just comes off? once thats off is it easy to gain access to the bolts , i know i have air con but still can get spanner in for sure
April 25, 201014 yr The splash gaurd should pull off the little clips away from the bumper. You seriously want to source a 13mm ratchet ring spanner to make light work of removeing the four nuts holding the front bumper on, with these removed you need to remove 2 screws either side in the wheel arch.
April 25, 201014 yr Author well that was a bitch to do ! all screws where stiff as and became rounded and took all sorts to get out , one of the bolts behind the bumper was rusted and became rounded too which i had to try all methods on and the hammer and chisel smackkkkkkk it rounnnd one worked lol
