Ok got a really strange problem on my mk5, 1.3 hcs carb manual choke
No batttery light with ignition on or choke or handbrake light
Start the car up everything seems ok but got no brake lights headlights or main beam
at this stage i checked battery voltage and it was 11 volts however if you rev the car the battery light comes on not bright but not dim, When the battery light is on checked voltage again and got 14 volts but still no brake lights headlights or main beam,
with battery light showing my light comes on for the choke when its pulled out but still no handbrake light
the horn hazard lights wipers heated rear screen indicators side lights and rear fog all work which is basically all the electrics it has being a base model.
Dont know if it makes a diffence but the green light comes on the dash to say the lights are on but just realised ive got no oil light either and noticed my temp gauge was sat lower than normal when on a run yesterday and also the relay doesnt click when applying the main beam and nor does the blue light to back this up.
So this is a really strange problem on a really reliable car with no electrical gadjets to go wrong lol its baffling me and i dont know what to do or where to look next so any help greatfully recieved cheers grant :cheers:
Check fuses earths and wires shorting, have you touched anything like lights or washed te car/been in the rain?
rain?.... in the UK???....surely you jest!
Not done anything mate its been parked up for a week went out in it and it was fine got back in it to come home and that happened?(
fuses fine and cant see no broken earths so not sure what to do now :nutter: :nutter:
