not sure if mechanical or electrical, so posted in here, move if in wrong forum
The heater blowers in my van only work on setting 3, nothing on 1 or 2
any one had this problem or know what it could be
cheers
cheers
had this problem a few times with customers cars, there is a small wire coil gadget on the heater fan under the scuttle panel which usually packs up causing this fault, cant for the life of me think of the exact name for the part. also could be something simple like the switch itself but in the past i have changed the part on the fan housing to cure that same fault :thumb:
i think its probably the resistors. they reduce the power going to to motor on settings 1 and 2 so it spins slower. thats the bit you need to replace
where can i get a new one of them? any online links?
