Posted June 14, 201014 yr Hi im on my 3rd MAF sensor now still not running great, when push accelerator fullydown holds backa little.someone has said to me when you get a new maf you need to reset the ECU. how do i do this? someone mentioned un-plugging the battery for 48 hours and this will reset it??? any help would be great cheers.
June 14, 201014 yr Hi im on my 3rd MAF sensor now still not running great, when push accelerator fullydown holds backa little.someone has said to me when you get a new maf you need to reset the ECU. how do i do this? someone mentioned un-plugging the battery for 48 hours and this will reset it??? any help would be great cheers. 30 minutes will do it.
June 14, 201014 yr Sounds like if its the 3rd maf then its not that causing the problems. Don't ask me what it could be though
June 14, 201014 yr Author ok will leave off drom fiday lunch till sunday night should do it, im hoping it should work, i fitted on sat, now after running a lil seems to be a little better, will leave bat off then drive sensibly through all gears etc. then after few days give it a thrash incase got coked up or something from wrong mix etc, if this doesn't work might go see garage they wanted 40 quid to plug in their diag machine.Cheers guys.
